Whine from in-tank fuel pump
Jack Schmidt
16
San Diego County
My 2003 4L is running fine. I'm just worried about it before we take a long road trip.
I can hear the high-pitched whine while I'm in the cab, the engine is running, and the windows are down, but not when the windows are up.
I tracked it to the low-pressure fuel pump by getting under the truck while the truck is running, just like you're not supposed to do.
Maybe the noise has gotten louder but it could be my imagination.
I replaced the pump assembly a couple years ago with a NAPA version.
Should I replace the pump again? Or is this noise nothing to worry about?
ericbphoto
Overlander in development
16,721
Wellford, SC
3.0L
6"
How full is the tank? The pump will seem louder with an empty tank. A full tank absorbs and deadens the sound more.
The fuel also cools the pump. If you habitually run around with very little fuel in the tank, that can potentially reduce it's lifespan because it will run warmer.
Josh B
1,988
Oklahoma
I used to run my 93 low on fuel almost continuously. I carried a gallon of gas in back so when it ran out I would use the gallon and know I had to get somewhere within 20 miles ;) It does make a bit of noise running it low but fortunately I never had any serious problem
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,542
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
First of all... it is a high pressure pump.
I can hear mine at times. Lower fuel level and seems when I'm sitting next to a building... think drive thru window.
Jack Schmidt
16
San Diego County
Thanks for the replies.
The whine is the same whether fuel tank is full or empty.
Almost every time I fill the tank I fill it completely, and I always run it to about 1/8 tank.
I called it "low-pressure pump" because I thought there was a high-pressure pump somewhere near the fuel rail. I guess there's only one fuel pump in this pickup. Thanks for the correction.
Jack Schmidt
16
San Diego County
Based on comments here I guess I'll just keep driving.
Milkman5687
30
North florida
Ford ranger
My pump was making a louder than normal wine that I could hear in the cab. I had my suspicions about the fuel filter, that was it in my case. I let it sit all night and changed it the next morning and the pump to tank line section had spewing pressure from the blocked filter. Pump noise gone immediately.
mikkelstuff
469
Brighton, CO
3.0L
Yes, change the filter first.
Jack Schmidt
16
San Diego County
Good tips about the fuel filter. Thanks.
It's only about 30k miles old but I will change it.
Jack Schmidt
16
San Diego County
Following up.
Replacing the fuel filter didn't help.
I replaced the fuel pump assembly just to be safe. The new pump is so quiet I hear it only during those first couple of seconds after turning on the ignition and before starting the engine, and if I have the door open.
The new pump was a huge relief during the long spring break road trip.
Milkman5687
30
North florida
Ford ranger
Nice. Glad you found the issue, piece of mind and confidence in your ride is invaluable.
