Will a 94 Ranger Differential Bolt in a 91 Ranger?
JesterGrin_1
San Antonio,TEXAS,Army Lodge 1105
4 cyl
I wished to ask if a 8.8 Rear Differential from a 1994 Ranger 4.0 or Mazda B-4000 will directly bolt into a 1991 Ford Ranger Extended Cab 2 Wheel Drive?
I am gathering parts for my 91 Ford Ranger Extended Cab 2 Wheel Drive Project as I already have the 2.73 Gear Set and a Posi Unit for an 8.8.
Thank You for Any Help.
wizkid00104
13
West Newton/Penn Hills, PA
2.3L/5.4L
Yes. It should not matter if it is a 7.5 or a 28 spline 8.8. Explorer rear axles (8.8 31 spline) will not bolt directly in.
scotts90ranger
4,535
Dayton Oregon
2.3 Turbo
The internals of a 28 spline 8.8 are the same between '91 and '94 but the '94 axle is wider, hats the only difference
JesterGrin_1
4 cyl
I am pretty positive that the current differential in the 91 Ranger extended Cab 4 Cylinder is a 7.5 and wish to bolt in a 94 Ranger 8.8 differential with little fuss?
As I understand it I think the 8.8 is 2" overall wider than the 91? And if so will the 1" difference per side present a problem?
Thank You.
PlumCrazy
2014 Truck of The Year
179
Millersport, OH
Solid Axle Swap 4x4
No problems. Only potential issue may be the rear driveshaft flange.....2.73s? that's a very uncommon ratio in the trucks. Are you sure you don't have 3.73s??
JesterGrin_1
4 cyl
The Gear Set is from a Mustang 8.8 as well as a posi unit. I plan to do a Diesel transplant. :)
Currently in the 94 Ranger 8.8 Differential I have 3.27 Gears.
I plan to use the truck for mainly transportation and working out of and of Course Hunting. So will probably upgrade the spring rates a bit and maybe some kind of small lift for a bit larger tires down the road for light off road use. Mainly in case it rains and I end up having to go through 20 or so Miles of Mud Road to get back to civilization lol.
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Awesome. If you need another set...I have a Crown Vic 8.8 sitting here with 2.73s.lol
Sent from XT907 using Crapatalk
JesterGrin_1
4 cyl
I might be interested in another good 5 Speed lol. Down here in South TEXAS they seem to be rare and expensive for some odd reason.
