will a m5od work on a 2.8?
7
murphy north carolina
2.8 v6
like the title says will it work with a 10 inch clutch and flywheel? i would like to rebuild a 2.8 and swap everything else in my truck with a 8.8 and d35 with newer trasfercase and all.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Yes, it will all bolt up.
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
2.8, 2.9 and 4.0L all share the same bellhousing bolt patterns.
90B24wd
Big Island Hawaii
Get one from a 4.0 cause the ratios are closer to the FM145 or the FM146.
mhughes165
9
302
ummmm no, wrong......the gear ratios arent closer for a 4.0 trans, if anything u want a m50dr1 that came behind a 2.9 (only a couple years) they have almost identical gearing to a fm145-6
90B24wd
Big Island Hawaii
That is not what the tech library has written. See for yourself.
The_Dealer
10
Macon, GA
Duh!
or get a 4.0 m5 and use 2.3 internals for lower gearing. u can also use the 4.0 m5od with 2.8 flywheel, clutch, and use the same year slve cyl. then u can use your current starter
mhughes165
9
302
90B24wd
Big Island Hawaii
So you're saying that who ever wrote the gear ratios for the FM145-46 and the M5OD is wrong then.
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Reading comprehension owns you.
7
2.8 v6
So from reading all the replys is it possible to put the first gear from a 2.3 m5od and the rest from. 2.9 m5od?
3,614
If you take the 1st gear, you need to take EVERYTHING. Bearing to bearing. There are subtle differences in the internals. They will work in the new case, but they need to go in as a set.
The_Dealer
10
Macon, GA
Duh!
its kinda like a ring&pinion set, its all matched as a set. yea u might could get by with just replacing one thing, but u are playing russian rulette. sooner or later somethings gotta go
btw if u read the chart it doesnt match up line for line with the applications. it says:
3.40 / 2.05 / 1.31 / 1.00 / 0.79 (4.0L Engines)
3.72 / 2.20 / 1.50 / 1.00 / 0.79 (All Other Engines)
how much more self explanatory can it be?:thefinger:
