Will D44 ttb hubs work on '79 D44?
vDawG
Truro NS Canada
Bronco 2
2.9
I just bought a 78 or 79 Dana 44 complete... except for the hubs are apart in a rubber maid container. I have a 96 f150 with the Dana 44 ttb and warn hubs. Will they go on and work properly? What about any other parts being interchangeable?
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
Yes they will work.
vDawG
Truro NS Canada
Bronco 2
2.9
What about the differential gears?
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
You more than likely have the high pinion axle so yes the gears will work. You need to make sure the axle from the 96 is a high pinion axle though.
vDawG
Truro NS Canada
Bronco 2
2.9
Are there any other parts that are the same ? Spindles, brake back plates, bearings, shotr side axle?
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Everything is interchangeable between the TTB 44 and the solid 44 except the knuckles and shafts (providing both are hi-pinion, the new body style mid 96+ F150 trucks started using the 8.8 front housing)
SVT
