Wiper Blade Arms Keep Popping Off From The Motor...
SykoRanger88
Purcellville VA
2.3l 4cyl
my passenger side wiper lever thats inside that little grill in front of the windshield keeps popping off, the passenger side wiper lever sits on the outside of the wipermotor shaft or wutever, it lasts like maybe 30 passes before it pops off then i just have the driver side wiper going, i usually take a clothes hanger and stick it down into the grill behind the hood to put that lever back on but im guessing that clip that is suppose to hold it all on there is messed up, my question is how the hell should i do this? does that piece thats in between the hood and windshield even come off so i can fix this problem?
Ranger Sport Honduras
Zoom Zoom
197
Honduras
Mitsubishi/Ford
3.0/2.3
Fortune Favors the Brave
pop the hood on the firewall there must be a little cover that u unbolt to access the wiper arm assembly
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
There should be a retainer clip that snaps into place on the motor arm...if you don't have one or it doesn't sit properly maybe take a trip to the junkyard to pick up a new arm...or one that has the clip functional...
strvger
19
the land of 2 seasons-Winter and getting ready for
2.3
my '83 has a ball-and-socket kind of arrangement. there is a plastic insert that goes into the flat shaft, then the ball on the arm pushes into that. the insert kept coming out of the hole in the shaft. i used some permatex adhesive sealant to hold that plastic insert into the shaft. so far so good. will know for sure after this coming winter gets here how well this fix holds up.
i didn't see any retaining clip behind the cover laying anywhere around. might try finding something like that if the permatex gives out.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Ah, well, the 83 models may have used a different method of keeping them on...but I like the retainer clips...easy to remove if you have to...not like my Zuki, that has a nut that I don't have a wrench for...
RobbieD
2.9l Mafia
3,567
Georgia
The '83 shop manual shows retainer clips. Maybe yours are just missing?
SykoRanger88
Purcellville VA
2.3l 4cyl
alright but that panel between the windshield and hood has to come off right? is it a real pain to remove? thanks
RobbieD
2.9l Mafia
3,567
Georgia
No; you gotta work it through the two small removeable panels, and then by pulling the motor. Copy this page:
[/IMG]
