MaineRanger
- Sep 15, 2009
- 0
- Ford
- Engine Size
- v6 4.0L
So about a year ago I was driving my truck at night to pick up the wife, about 100yds from the house i her a louad thud from under the hood followed by the loss of power steering and lights fadeing quickley. the next day i founf that the tensioner pulley had cracked in half and let the belt shoot off. i replaced the tensioner that week end and put on a new belt. no problems for about a month( winter month) then the belt starts to chirp when i start it up, at first, the sueal after about a month of chirping. its beginging to be spring now. the squeal truns into a full blow scream in about another month and it does not happen just at start up its alomost the entire ride. late spring now, i had ordered a goodyear gator belt and out that on, did good all through the rest of spinrg and summer. i also put in a new altnator this summer. fall starts to set in and i start to get the chirps again, shortly followed by the screaming, only now when its screaming the battery starts to drop as well. my first thought was the alt for the battery problem but i tested it and it works as its supposed to, the belt is slipping across it and now spinning it, Right? back to the screaming though, i replaced the trnsioner pulley after finding that it was loose and the bearings were bad in it. also scuffed up the other pulleys and greased the tensioner to ensure it was free moving and not getting hung up on its own spring, which its not. i also found that the idler pulley was not up to par but was still functional and didnt make any noise when free spun. THE SCREAMING IS STILL THERE and i have run out of ideas. what do you guys think, any ideas would help
