Dogface
- Dec 2, 2011
- Reaction score
- 0
- Make / Model
- Ford
- Manual
The problem I`m having is, the thing starts up right away idles perfectly, then I start down the road go 1000ft or 1500ft to a stop and it starts to miss and shake and has no power. It will do this untill it is at full operating temp then it runs fine and idles like a singer sewing machine. I have ohmed out the temp sensor and the values change as the temp changes, other things have been replaced just not the temp sensor.
Can the temp sensor be faulty midway and will that make it misfire and send
a code? I have not had a Temp sensor code yet just the misfire. I plan to replace the sensor but thought I would see if anyone has had this problem before, Any ideas!
Thanks
Thanks
