metrobillyg
- Oct 16, 2008
- Reaction score
- 0
- Location
- Spanaway WA
- Make / Model
- Ford
- Engine Size
- 2.9L
- Automatic
- My credo
- Work smarter not harder!
1988 Ford Ranger 4X4 STX extended cab. I had little brake pedal, newer pads, and calipers in front newer shoes in rear, no leaks. Replaced booster and master cylinder still not much better after bleeding entire system. Did some reading and it was suggested that the vacuum pump could be the culprit but don't know what it looks like or where it is located, can't find it listed in the chilton manual as vacuum pump? According to a video I found it seems simple to test but
where is it?
where is it?
