Bellhousing bolt pattern
RockRanger
7
Fresno CA
Does anyone have the 4.0 bellhousing pattern as either a cad drawing or as a dimensional drawing?
Sent from my SM-G920V using Tapatalk
I don't have either of those, but I have an engine gasket plate that I could use as a template to make a drawing and send you a copy.
RockRanger
7
Fresno CA
That might work. I want to build an adapter to run an np435 behind my 4.0. Just want to do it without pulling my transmission to get dimensions off of.
RockRanger
7
Fresno CA
That looks like it might have what I need. Is it missing one bolt in the lower right corner. Maybe a starter hole. Nice find
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Check through rulebreaker's posts.(or PM him, Chads a good guy.) He put a np435 behind his 4.0l in his Aerostar. IIRC, he used a TK4 bellhousing and an adapter plate.
