Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 11-28-2017, 03:50 AM   #1
snahman
snahman is on a distinguished road
Default How Many o-2 sensors on '91 Ranger 3.0..?
Hello..Heard different that there's two. Is it heated or non heated..?.. I haven't been able to get under truck ( arthritis now....Where's it located..?.Thanks..!
snahman is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 11-28-2017, 11:38 AM   #2
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger
RonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant future
Default
1994 and earlier Rangers used only Upstream O2 sensors, no O2 sensor after the Catalytic converter(Downstream), that started in 1995 model year
Pre-1995
4cyl engines just had 1 upstream O2 sensor
V6 engines usually had 2 upstream sensors, one on each down pipe from each exhaust manifold before they "Y"ed together
But some older V6 engines did have just 1 O2 on the "Y" pipe
1991 3.0l should have 2
You can usually see them from engine bay, and unplug them also, but access to remove them is usually from under the truck
O2 sensors are all the same there is no left or right(or upstream/downstream), but.............they all come with leads and connectors attached and the length of the lead may be different from left to right, depends on the vehicle wiring harness of that year.
The connectors are also all the same so DO NOT mix up left and right plugins, do one O2 sensor at a time and plug it back in to correct wiring harness plug
All were Heated
4 wires at O2 = Heated O2 sensor
RonD is offline   Reply With Quote
Old 11-28-2017, 02:55 PM   #3
snahman
Default
Quote:
Pre-1995
All were Heated
Ok, thanks for that..Wonder why the aftermarket sells them that says it fit with only 2 wires and non heated....?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
FS: Brand New Oxygen Sensors for 3.0 Ford Ranger (IN) Hillyard Parts For Sale 1 02-16-2015 10:09 PM
88 Ranger Running hot after new sensors petemaresco 4-Cylinder (2000 & Older) 17 11-22-2012 12:55 PM
3.0 VS 4.0 Sensors? tj37 4.0 Liter Forum 0 05-08-2012 12:19 PM
1995 Ranger, 02 sensors, MAF & hydroxy outomyelement 4-Cylinder (2000 & Older) 4 07-05-2008 11:31 PM
abs sensors 2wd 96 ranger rapsucks_07 Brakes 4 10-12-2007 03:27 PM
1999-2018 / 959 Media LLC / All Rights Reserved
