Home | Ford Ranger Forum | Builders Guide | How To Tech | Other Articles | Featured Rangers | Readers Rangers | Classifieds | Shirts & Decals |
#51 |
Vehicle Year: 1994,1995
Vehicle Make: ford
Vehicle Model: ranger 4x4 auto,explorer 4x4
Rep Power: 0 ![]() |
Ok im putting a 93 3.0 in a,2000
When i install the cam sensor do i set it at75* which the book says is for 96-97 or do i set it at 38* which is for 98-2008? The 93 had a distibutor, and im swapping it out with a cam sensor. I guess my question is did the cam change somewher in there? Why the difference,and which one do i use? |
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member. |
#52 |
Vehicle Year: 2000
Vehicle Make: Ford
Vehicle Model: RangerXLT,3.0 Flex
Hi Nicky,, on those real cold mornings, does it start and stall off and on?
#53 | |
Junior Member
Vehicle Year: 1996
Vehicle Make: Ford
Rep Power: 2 ![]() |
![]() Quote:
Anyhow, the 10 degrees ATDC and 30 degrees off of the engine center line looking backward worked for me. The check engine light went off immediately and hasn't come back. The truck runs fine. Measured gas mileage coming in to work this morning - 37 miles of freeway was 23+ mpg. There are timing marks on the crank shaft pulley. The center bolt on mine was 13/16. The gear teeth are 10 degrees apart. You can see the timing make from below with a flashlight and a mechanics mirror. If you're using the plastic tool you can take the fasteners out of the old sensor and use them to fasten down the tool temporarily. That way it won't slip off. If you don't fasten down the tool it slips off easily. I used a little dosing syringe I had left over from having a cold to inject some engine oil in the lube hole and then spun the shaft around. Then I lubed up the worm gear and the o-ring. These comments are for a 1996 ford ranger with a 3.0L V6. Other years and other engines are maybe different. What I've posted worked for me. Oh yeah, it was a real pain to accomplish- took me the better part of a day - I'm not a mechanic. |
Bookmarks |
Thread Tools | |
Display Modes | |
