Before performing ANY diagnostic procedures on your engine...
AllanD
TRS Technical Staff
TRS Technical Advisor
134
East-Central Pennsylvania
1987... sorta
'93 4.0
I see this time and time again "my engine does this and that!"
And there's usually a raft full of followup questions people ask
trying to work the problem....
In my considered opinion the FIRST intelligent question is the one where someone
asks "Have you changed the fuel filter"
All OTHER questions are jumping ahead in the logical thought process
It's like someone saying "I saw a dead animal alongside the road!" and
all the immediate follow-up questions are describing the different known
species of unicorn....
If you suspect that one of your legs is suddenly shorter than the other
you think ya'll might look to see if you are wearing shoes that match
rather than a wrestling flat on one foot and a cowboy boot on the
other before you rush off to see an orthopedic surgeon to shorten the long leg?
Lack of power on a 4.0 is more often not a fuel issue, because the ignition
generally works... or it doesn't.
there is no question of the ignition of the engine runns at all because the
two common modes are workign perfectly or not at all anything else would
be very odd... one in 10,000.
And if the fuel filter doesn't work pull the lid off the airbox and check for
leaves mouse nests and dead chipmunks (the crap collects UNDER the filter)
Last fall I had a problem, a noticeable "lack of power", I replaced the fuel filter
and it didn't go away... next on my thoughts was the airbox...
what did I find? it was packed full of that silky crap that the rag weed and milk
weed plants use to distribute their seeds on the wind....
Yup my airbox had collected about a pound of the stuff and it was
obstructing airflow into the engine... problem solved... never even
thought of reaching for my EEC4 scanner (I have a good one too, not a $20 "beep box")
Next on my list would have been pulling the spark wirees out of the coil packs
one by one and looking inside, if you see anything other than shiny aluminum
(or brass on an aftermarket "performance coil pack) you've probably found
your problem, but ignition doesn't cause a general lack of power it cause
uneven idle or an outright "miss" ranging from a "soft miss" that you only notice
under specific circumstances to a "hard miss" which is constant under ALL circumstances.
spark plugs can cause some weirdness, generally worn plugs will idle great,
but will only misbehave at high rpm or under heavy load that's because the
bigger the gap or the higher the load even the harder it is to fire the mixture
I might have reached for my code scanner if I had needed to but...
please check the "Stupid stuff" before posting....
AD
Big Jim M
30
Austin
4.0
Persorming???
Persorming??
In my considered opinion the FIRST intelligent question is the one where someone asks "Have you changed the fuel filter"
It's like someone saying "I saw a dead animal alongside the roadl" and all the immediate follow-up questions are describing the different known species
of unicorn....
you think ya'll might look to see if you are wearing shoes that match rather than a wrestling flat on one foot and a cowboy boot on the other before you rush off to see an orthopedic surgeon to shorteh the long leg?
Lack of power on a 4.0 is more often not a fuel issue, because the ignition generally works... or it doesn't.
there is no question of the ignition of the engine runns at all because the two common modes are workign perfectly or not at all
anything else would be very odd... one in 10,000.
And if the fuel filter doesn't work pull the lid off the airbox and check for leaves mouse nests and dead chipmunks
what did I find? it was packed full of that silky crap that the rag weed and milk weed plants use to distribute their seeds on the wind....
Yup my airbox had collected about a pounbd of the stuff and it was obstructing airflow into the engine... problem solved... never even thought of reaching for my EEC4 scanner (I have a good one too, not a $20 "beep box")
Next on my list would have been pulling the spark wirees out of the coil packs one by one and looking inside, if you see anything other than shiny aluminum (or brass on an aftermarket "performance coil pack)
you've probably found your problem, but ignition doesn't cause a general lack of power it cause uneven idle or an outright "miss" ranging from a "soft miss"
that you only notice under specific circumstances to a "hard miss" which is constant under ALL circumstances.
spark plugs can cause some weirdness, generally worn plugs will idle great, but will only misbehave at high rpm or under heavy load
that's because the bigger the gap or the higher the load leven
AD
alwaysFlOoReD
Forum Staff Member
TRS Banner 2012-2015
5,096
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
I agree, my diagnostic procedure sucks. I'm one to jump to conclusions so, is there or could you write a general procedure to follow. [Or maybe I'll buy a repair manual :icon_surprised: Even those don't help me much, I'm to easily distracted- oh, that sure is shiny/cool, wonder if I can make one:icon_confused:]
Or a list of more stupid stuff to check first.
Richard
Angie
368
Vancouver area BC Canada
92 & 83 project
Engine Type
V8
4.0L 302
Engines work on this concept Gas - Air - Spark ... take away one of those and you have a problem (as Allan said) you can't drive on an empty tank so think in this way:
G. gas
A. air
S. spark
Jason
28
(formerly) 200
Wouldn't you check the airbox first? I do agree though.
We used to have those "alternator, starter, battery, fuse" type of techs at work. Boy they made me a ton of cash.
modelageek
14
Boston, MA
Engine Type
4.0
2WD / 4WD
of unicorn....
AD
Great honest post.........I am just becoming reasonably comfortable with my knowledge level and I have started to preach what you said.....the fuel filter does not get changed enough and 90% of all issue would not have happened if people followed the maintenance schedule......
scheetz21
G. gas
A. air
S. spark
that is true but wont get any where with out compression...suck, squeeze, bang, blow, but usually if your truck that's stops running one day prob is a "GAS" problem.
jimbo59
hope ar.
ford
4.0
following previous advice ! lmao ! i have a 2000 ford ranger 4.0 v6 , automatic 4x4 , 272,000 miles and change.
fuel filter changed , spark plugs changed , air filter changed ( with box cleaned out ) and fuel pressure damper replaced .
problem ! when engine is cold it floods all cyclinders with gas ! thus the engine wont start , once i remove all plugs and clean them and blow off excess gas it will start and run , until later when the engine cools and it starts all over again ! sometimes as long as a week later !
it has been in 2 local shops ! to include the local ford dealership ! and no one knows why its doing this ??????
just short of insurance fraud ? and ideas !!!!!!!!!!!!!
spiralthomas
valvetrain...
chased my 94 4.0 isuue for 1&1/2 years, ignition+fuel+eec all gone over. should have listened to the first guy that said 'burnt valve' - the main issue w/these motors seems to be valvetrain(rockers, lifters, pushrods) which look like other problems, especially to those who don't want to believe their engine needs gutting. check the posts regarding valvetrain issues, also check your intake&exhaust bolt torques before it's too late...
  • Like
Reactions: gaz
coopab
Central Massachusetts
4.0 L
persorming???
Typos are a PITA
AD
Unless the typo makes the meaning unclear I follow this motto from my tagline file.
"All spelling and grammar errors are intentional. Grammar Nazis' need entertainment"
kimcrwbr1
46
maplevalley WA
ford
2.8l
If the engine has a PCV valve just replace it when you replace the air filter. It is impossible to clean properly and part of preventive maintenance. Thats more for fuel economy unless your ignorant enough to let it get bad enough to cause running issues. In that case disconnect the battery for about an hour to reset the computer values after you replace it...
Dirtman
Former Middleweight Moss Fighting Champion
13,326
41N 75W
Engine Type
2.3 (4 Cylinder)
2WD / 4WD
2WD
It's up there.
Total Drop
It's down there.
Round.
I poop in the furnace.
You know why I thought it would be all over and you set up with the balancer off of your account to make laws and you will see where you are going and how to stock up for the full time you fill out the driveway for your second question.
billpac4u
68
St Louis
Ranger
Engine Type
4.0
2WD / 4WD
rubydist
858
Denver
Ford Ranger FX4
Engine Type
2WD / 4WD
From my point of view, the first intelligent question is "what are the codes?"
Staff online
Members online
Shran
April Truck of The Month
