Fuel Pressure On a 2011 4.0 location
mjordanlmj
ford
I have a cyl # 3 misfire and all 6 injector faults and raw fuel smoke coming out tail pipe, want to check fuel pressure regulator but cant find it. Where did Ford hide it???
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
You can't really check the fuel pressure regulator on that engine unless you have a fuel pressure test port, which not all of them did by that year.
Fuel pressure regulators are used on true return-type fuel systems. Your truck has what Ford calls a "Mechanical returnless" system, which is still technically a return type system. It's called "returnless" because the fuel going back to the tank never gets to the engine.
Your fuel filter has three ports for line connections. The large one at the rear is flow in from the tank. The large one by itself on the front is flow out to the engine. The small rear-facing one is a return to the tank. There is a valve in the fuel filter that closes when system pressure hits a certain point and diverts fuel back to the tank, and then as pressure drops off it starts opening again. Eventually it hits a spot where it is just dwelling, but that is beside the point.
The point really is if you suspect excess fuel pressure replace your filter.
mjordanlmj
ford
Any suggestions on why I have all injectors showing fault on scanner?
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
If it runs, not really.
The injectors all get power from a single bus, but are grounded individually by the PCM to open and close them.
If it runs that system is likely working.
RonD
Official TRS AI
TRS Technical Advisor
8,370
canada
Welcome to TRS :)
Fuel injection computers have a "Clear Flooded Engine" mode
Key on, engine off
Press gas pedal down to the floor and hold it down all the way
With RPMs at 0, and TPS(throttle position sensor) at 4.5volts, computer will turn OFF fuel injector pulses but spark stays on.
Now crank engine, it should not start, no fuel, if it fires or starts then fuel is leaking in.
If RPMs get above 400(engine fires), Computer will exit "Clear Flooded Engine"
If you take your foot of the gas pedal computer will exit "Clear Flooded Engine"
I use "Clear Flooded Engine" every morning when I start my high mile 4.0l, I want to get oil circulating for about 10-15 seconds, then I let off on gas pedal for start up
Staff online
Shran
April Truck of The Month
