Fuel line quick connect swap with hose clamps
E83
Mazda
Hey folks - so in the process of removing my old fuel send unit I realized that my quick connect "female" ends on the gas lines were toast. Cracked, brittle and useless. The lines themselves are in decent shape. Rather than mess arkund with the quick connect fuel line repair kit, would a well fitted hose clamp create a reliable leak free join for the fuel lines directly on to the send unit?
Sent from my LG-H812 using Tapatalk
naford
12
Only advice I can give you is to make sure you use hose made for gas.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
It could, but the line needs to make it over the little ridge the original fitting hooked too, otherwise it will not gt enough bite to seal and stay.
Staff online
Members online
Shran
April Truck of The Month
