99 4x4 problems after bearing replacement
94fourbyfour
I just got done replacing a wheel bearing/sensor on my brothers truck its a 99 4.0 5spd 4x4, Replaced said parts for low speed abs activation/sensor dropping out. Now its all back together and the abs is fine but the lf hub makes noise in 2wd 30mph+ if you turn the switch to 4 hi it goes away, it sounds like cards in a bike wheel, Is there a certain way the hub needs to be installed (locked or unlocked? anyone know what the culprit is? I find it hard to belive it just failed at the same time.
thanks in advance, i wish he would have got a 85-97 truck:mad:
Staff online
Members online
Shran
April Truck of The Month
