Bleeding front calipers
Denisefwd93
74
South East PA
Replacing rotors pads calipers on the front of this 94 four-wheel drive. There are two lines on the driver side connected to 1 hose. Not something I was expecting. does this pose a problem when it comes to vacuum pulling the fluid through?
Thanks in advance!
Shouldn't. Unless there is a leak somewhere.
Denisefwd93
74
South East PA
Ready for bleeding! Brake fluid that is, well I guess you could say bank account also, lol
The pads and slides are in I didn't take pictures of that,. just in case anybody notices. :)
Denisefwd93
74
South East PA
Denisefwd93
74
South East PA
I noticed something almost nobody uses the anti rattle clips for the inboard brake pad, they fit pretty loose without it!
