non tach cluster to tach cluster 83 ranger
rab
3
merkur
1st off im new to the ranger.
i have a 83 ranger carbed 2.0 4 speed 2wd and it has a non tach cluster in it, i want to install a stock tach cluster from the same era in it.
i will be doing a 2.3 efi turbo swap into it.
im unsure if i will use a efi ranger harness or the merkur harness, and will just hard wire the powers,fuel pump and grounds.
i wont be doing the efi turbo swap untill next spring,but would like to find a tach cluster and swap it in now.
so what years had a stock tach cluster that matches my truck, ie 80's style,?
will there be any extra wiring i have to do?
is it better to swap the whole cluster, or just swap the tach part to mine, i would think the whole cluster?
inuyasha2875
Post Falls Idaho
FORD
2.8,2.9
i've looked at tring the cluster swap but the wireing harness is diferent for the two clusters
rab
3
merkur
has anyone done this?
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,915
SW Iowa
Engine Type
V8
5.0
You will have to repin the connector for the tach side of the cluster or swap dash harnesses.
I am saving mine for a winter project, but there is a thread going on it. Since you won't be running a V8 forget the part about jumping the two poles. Not sure how to make a V6 tach read for a four cylinder though...
http://www.therangerstation.com/forums/showthread.php?t=113129
Clusters that fit came in trucks 86-88.
kaytbugsdad
Antelope CA
2.3 turbo
I have a turbo swap done already on my truck, and just swapped in a factory tach from a 4 cylinder truck, repinned the gauge connector on the backside of my cluster....... Everything works as it should, except for the tach. I have an aftermarket gauge in my truck already (which tested accurate), when the aftermarket gauge is reading 2500 rpm, my factory tach is only reading 1750 rpm....... Not sure if I missed something when I wired it up (resistor or something like that)?
rab
3
merkur
were is this info on the pinouts of the cluster?
so there were factory 6 and 4 cyl tach clusters?
kaytbugsdad
Antelope CA
2.3 turbo
I'm not sure...... I would have to say yes, though. I have a tach from a 6 cylinder and a 4 cylinder, and the 2 circuit boards are different, even though the part number for the tach face is the same...... I have had both tachs in my truck already, and they both are operating in the same way (2500 on timing light tach is reading 1750 on dash)...... I was at the wrecking yard one day and took two dashboards apart (one no tach, one with tach), and traced the wiring down, drew pics of both connectors, and re-pinned the connector in my truck (originally no tach) to match the connector in the truck that had a tach.......
kaytbugsdad
Antelope CA
2.3 turbo
Found a wiring diagram that shows a resistor in the wire to the tach....... Gonna go find one, I'll let you know if that does the trick or not!
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,915
SW Iowa
Engine Type
V8
5.0
Keep us posted. :icon_thumby:
An article in the library on the finer points of switching between no tach and tach would be awesome... people gotta experiment with it first though.
kaytbugsdad
Antelope CA
2.3 turbo
Went and found a resistor for my truck..... Didn't change anything!!! Guess I'm gonna have to do it the old-fashioned way..... Talk to someone who works with electrical stuff!!!! I'm not good with figuring out how resistors work, but my dad is an electronics technician, he'll know what size resistor I have and what size I need to replace it with!!!
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,915
SW Iowa
Engine Type
V8
5.0
It has been awhile so I can't give you the specifics, but the number and color of the rings tells you how many ohms of resistance it is. There should be something on the internet to give the specifics on what is what.
kaytbugsdad
Antelope CA
2.3 turbo
Found the issue as to my error in my tach readings....... it seems, somewhere down the line, the ignition module was replaced...... with one from a 2.9!!!! Everything from the 2.3 and the 2.9 is the same, except for the tach output readings!!!! Installed one for a 2.3, tach reads perfect!!!!! The two modules are 2 different part numbers.......
rab
3
merkur
ok cool, so are the gauge clusters from the v6 and 4cyl the same or different?
do you have the repinning info?
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,915
SW Iowa
Engine Type
V8
5.0
SenorNoob
584
Middle Tennessee
Engine Type
4.0
2WD / 4WD
1.5" Front + 4" Rear
245-70-R16
I'd say the clusters are the same. There is just an extra ground for one setting. I wanna say it's grounded with a v6 but that doesn't make much sense. It has something to do with the PPR (Pulses per Revolution).
Staff online
Today's birthdays
Mudtruggy
May Truck of The Month
