5th wheel hitch brackets for 2002 Ranger.
Tractorman
GB, Wisconsin
4.0
Just looking to see if anyone makes brackets for the Ranger for a 5th Wheel hitch.
I don't wanna hear "you can't pull that!" or anything of the sort.
If you know where I can find them, great. Or if I need to get universal ones, well just as well.
Thanks.
Spowerback
Banned
--- Banned ---
California
FORD
v6 4.0L /
hitch center
help me
his of that you speak
Tractorman
GB, Wisconsin
4.0
Ok, I have the rails. All I need are those L shaped brackets. I've searched online, but couldn't really find them. Maybe I'll be making my own.
nate09
6
green bay, wi
just curious what you plan on pulling? seeing as youre from GB ill be on the lookout.
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
Engine Type
V8
6.6L
2WD / 4WD
5"
35"
Husky makes a set. However, the universal set will work just fine.
Tractorman
GB, Wisconsin
4.0
I see that Husky has Ranger brackets. I have a Robin Industries hitch and rails. They should match, correct?
ford1386
Solid Axle Swap
Gardners, PA
306
I have a set of the L brackets left over from when i put my fifth wheel hitch on my super duty they came with the rail kit but i bought the custom brackets for under the bed instead..............$40 shipped if interested
Tractorman
GB, Wisconsin
4.0
1995 Shadow Cruiser 5th wheel camper.
Ok, I'm assuming they're universal mounts? These would need holes added to the frame, correct?
Thanks
ford1386
Solid Axle Swap
Gardners, PA
306
they are universal mounts, i'm not sure about the holes in the ranger frame but i would assume so.............
i looked on huskytow.com and it doesnt specify whether or not they are the custom brackets to fit the ranger frame or whether the kit comes with universal brackets
Tractorman
GB, Wisconsin
4.0
Just an update/completion.
Bought the Husky brand rails and brackets for downsized truck, which is made for the Dakota and Ranger. Finally got around to installing it today.
Installation was easy enough. Set the hitch on top of the rails, measure ( and measure and measure!) and drilled the 4 holes through the bed for the bolts to the brackets. Add the spacers where needed, and then drop the bolts down the bed rails.
The next part is to loosely bolt the brackets up to mark the holes that need to be drilled to attach the brackets to the frame. These holes are supposed to be a 17/32" drill bit, but only had a 1/2" available. Just drilled a pilot hole, and then the 1/2" bit, and then removed the bracket so I could wobble the hole a little bigger. Not ideal, but the wheels bolts all seated properly.
On the driver side I had to watch for some electrical lines and the brake line, passenger side was clear.
The center of the hitch is back an inch and a half of the center of the axle, which isn't exactly what I wanted, but it still tows like a beauty. Weighed the camper (no water) and crossed the scales at 8920 pounds, giving me about 600 pounds of GCVW before I'm maxing out according to the book. Has plenty of power still, holds 'drive' well on hills and overpasses at 60 and 70 mph. Truck and camper sit very level, looks well together. Rear springs are tired at 140k hard miles, but still rides great.
Overall, gotta say I'm glad the camper I found was a 5th wheel! Now I just have to buy a goose neck plate and covert my car hauler over....
Will
Forum Staff Member
514
Gnaw Bone, Indiana
Toyota
4.0
Is it this thing? That's perfect.
Tractorman
GB, Wisconsin
4.0
Yes it is, but mine looks shorter than that.
Will
Forum Staff Member
514
Gnaw Bone, Indiana
Toyota
4.0
I think that's a 25.
The nose cone does wonders I'll bet. The pressure is about half at a 30 degree angle, which that looks to be.
pcollins
7
Middle of Nowhere, NY
GMC
4.8L
just remember to do earlier tranny fluid changes and i don't see why the truck Cant pull it.
Jspafford
15
Lancaster, Ohio
Chevy 3500HD
Engine Type
V8
6.6L
2WD / 4WD
5"
35"
Glad you found the husky parts.
Staff online
Members online
Shran
April Truck of The Month
