Torsen or track-loc?
ericlerouge
Quebec, Canada
2.3 td
Its for a 2wd, duratec 2.3, 2009 Mazda truck. I currently have a 3.73, 7.5 inches open diff. I want to upgrade my axle for two main reasons:
I need 4.10 gears for towing my small camper trailer, it's not that bad but will be better going uphill a little faster and easier...
Second reason is I'm in Eastern Canada (Quebec) we get a lot of snow and ice, and want a LSD.
I've found a torsen axle with 35000 miles for 515$ cdn and a track loc with 110000 miles for 356$
Which one would be better for ice and snow driving? I had LSD in the past on other vehicles and like them very much.
Don't know how a torsen works on ice and snow....
Envoyé de mon XT1563 en utilisant Tapatalk
8,370
Torsen is gear driven LS and Track Loc uses clutch discs LS.
Torsen is considered a heavy duty LS, Track Loc medium duty
The 4cylinder or V6 engine would be fine with either
For the $150 difference and lower miles I would go with Torsen
But I don't think there would be any noticeable difference in your setup, with snow or ice
85_Ranger4x4
17,835
SW Iowa
I have a trac-lock in mine. Works like a locker in snow/ice, both tires turn. Wants to kick the rear out a lot in 2wd... great fun.
Personally unless you run chains or something I would not want it on a 2wd in snow, mine needs 4wd to keep it pointed the direction I want to go. I was all great guns to put it in my dd too, after doing the Ranger I just regeared it and left the open carrier in it (it is also 4wd)
Mine also has mud tires and no weight in the rear, all I do in the winter is bust snow drifts for giggles in my field (I don't drive it on the road in the winter) so your results may vary that way.
ericlerouge
Quebec, Canada
2.3 td
I really enjoyed lsd in winter here, we get used to drive on ice and snow, i do put 300lbs of sand bags betterment the wheel wells and use skinny studded winter tires. It does pretty good right now, but I have to leave the truck parked outside for extended periods ( a week or so) to go to work, when I come back the truck is usually buried under 1 foot of snow and with the action of the sun on nice days the wheels are stuck in the ice... My concern was that a torsen would act more like a locker turning corners and not like a limited slip, so the torsen I will get, thanks for the answers.
ericlerouge
Quebec, Canada
2.3 td
* between the wheel wells
ericlerouge
Quebec, Canada
2.3 td
Finally found a 8.8 4.10 gears limited slip with really low miles for 350$ cdn going to check that out on Friday...
