Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 03-29-2012, 10:13 AM   #1
firedawg
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Explorer
firedawg is on a distinguished road
Default 4.0 exhaust backfire, won't start in SC
Breaking down and asking for help finally... got a 94 explorer manual 270k that i've been messing with for 6 months. Not my primary vehicle but I miss the gas mileage. Problem started way back with a slight stumble which I figured fuel filter. Got progressivley worse the following days where it would idle find but when you hit the accelerator it would stumble and pop. Got to the point where it wouldnt go anymore. Actually got it started maybe 4 months ago and it idled nice and smooth but when you gave it gas it went stupid again. It showed some EGR codes that I never pursued. Now when cranking it backfires thru the exhaust and pisses all the dogs off in town.
Ignition module (checked twice), coils checked, new crankshaft position sensor, fuel filter changed, fuel pressure around 36 if I remember right. Changed out the computer today for one bought from a fellow member on this site, no change. I'm a decent shadetree mechanic but I need some direction with this one.
Seems like timing but when I had it running last it idled perfect. I'm thinking timing advance maybe? I understand there is a sensor in place of the distributor, heard its a bear to get to. Figured the computer reads both sensors on the cam and crank. Timing issue due to mileage? Not sure of maintenance history on timing chain? or belt? since ive only had it a couple of years.
Any suggestions or checklist to start from the top off? Thanks for reading.
Tony in SC
firedawg is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 03-30-2012, 07:03 AM   #2
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Making money and being broke.
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Now is the no start issue limited to South Carolina, or does it continue into other states?
There is a sensor in the back where the distributor would be, and it is used for timing advance, you are correct.
I would also agree that it sounds like you have a timing issue. It runs fine at idle so your base timing is OK. It's backfiring out the exhaust when you rev it, so your timing is not advancing. I'd hit it with a cam sensor and see what happens.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: Cash 'N Carry
Project: 12-Volt Sandwich, project finished
Project: Birthday Present
Quote:
Originally Posted by The Doctor
Hunger looks very much like evil from the wrong end of the cutlery.
I like it when things catch fire and explode, which means I do not have your best interests in mind.
adsm08 is offline   Reply With Quote
Old 03-30-2012, 07:11 AM   #3
firedawg
Vehicle Year: 1994
Vehicle Make: Ford
Default
Thanks for reply. The state comment had an alterior motive. Again thanks for the direction.
Old 03-31-2012, 10:09 PM   #4
marauderx
marauderx's Avatar
Vehicle Year: 1991
Vehicle Make: FORD
Vehicle Model: Ranger with modified wide bed
marauderx is on a distinguished road
Default
Lots of sarcasm around here man, just roll with it, bust some balls back at em, and laugh with us. I am from the muddy coast/Cajun country where we eat anything that moves, adsm08 probably eats philly cheese steaks 3 times a day, and we have had a few no start Q's come out of SC... Let me restate the Mantra- "Check the Grounds" Repeat 25X-
marauderx is offline   Reply With Quote
Old 04-01-2012, 07:12 AM   #5
firedawg
Vehicle Year: 1994
Vehicle Make: Ford
Default
Which grounds? the one beside the computer looks fine. Battery ground?
Old 11-21-2014, 02:02 PM   #6
redjmp
Vehicle Year: 97
Vehicle Make: ranger
Vehicle Model: xlt 4x4
redjmp is on a distinguished road
Default
Did you ever resolve this problem and find out the cause?
redjmp is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
