- Sep 6, 2007
- Reaction score
- 0
- Age
- 38
- Make / Model
- Ford
- Automatic
I got a set of 1985 Ford 1 tons (D60 & 10.25 Sterling) from a buddy. I plan on lincoln locking the rear and running a lockright up front. I am just going to keep the factory gears (4.10). I figure once I put the doubler in it will be a nice crawl ratio and even in 4 Lo the V6 will still be able to turn the tires pretty well. I am going to run Ranger leaf springs up front, probably taking out the bottom leaf so the lift isn't too extreme. Depending on clearances I will ditch the 3" BL. I am going to run hydro assist steering and I still need to order a DIY BTF diff cover for the rear. I will probably wait a while to go to 35 spline externals and lock outs up front.
Here are some pics.
Got some parts.
new u bolts and spring plates for the rear. These components are beefy!
new diff cover for the front. It is all 3/8"
Yanked out the old axles. Still need to take out lift brackets up front. Started to mock things up to see what it would look like with the new axles and tires. Not exact but gives you an idea. The truck will sit a good bit higher when on the axles. It was pooring rain when I took the pics.
The tires in the pics are 39.5 PitBull Rockers.
Here are some pics.
Got some parts.
![](http://memimage.cardomain.net/member_images/3/web/2475000-2475999/2475556_181_full.jpg)
![](http://memimage.cardomain.net/member_images/3/web/2475000-2475999/2475556_182_full.jpg)
![](http://memimage.cardomain.net/member_images/3/web/2475000-2475999/2475556_183_full.jpg)
![](http://memimage.cardomain.net/member_images/3/web/2475000-2475999/2475556_184_full.jpg)
![](http://memimage.cardomain.net/member_images/3/web/2475000-2475999/2475556_185_full.jpg)
![](http://memimage.cardomain.net/member_images/3/web/2475000-2475999/2475556_186_full.jpg)
![](http://memimage.cardomain.net/member_images/3/web/2475000-2475999/2475556_187_full.jpg)
![](http://memimage.cardomain.net/member_images/3/web/2475000-2475999/2475556_188_full.jpg)
