Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 09-12-2012, 02:28 PM   #1
eliteconcept
Vehicle Year: 1990
Vehicle Make: ford
Vehicle Model: ranger
eliteconcept is on a distinguished road
Default fuel supply line leak, how to fix
Greetings,
My 90 supercab has sprung a leak. The fuel supply line right about in the middle of the tank and the fuel filter has developed a hole and sprays gas when its running.
This is purely a weekend random use truck for odd jobs around the house, so I would like to keep the fix cheap and fast if at all possible.
Would something like this work, maybe not this exact part but something like this
http://shop.advanceautoparts.com/web...rd}#fragment-2
advice welcomed!
Thanks
eliteconcept is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 09-14-2012, 07:30 PM   #2
epi_sg
Vehicle Year: 1988
Vehicle Make: ford
I use this vehicle for: every day driver
epi_sg is on a distinguished road
Default also have leak
I have a leak also, and i am under the suspicion that it may be the source of my problem. where the line comes out of the filter there is a plastic tab? thats where my leak is, when it is running. Can this also cause fuel pressure problems and make it seem like you have a pressure regulator problem.... thoughts.
epi_sg is offline   Reply With Quote
Old 09-14-2012, 08:50 PM   #3
eliteconcept
Vehicle Year: 1990
Vehicle Make: ford
Default
Nope leak is just where it looks like the nylon / rubber fuel line has rotted away, its on a straight piece of line not near the filter or gas tank.
Old 09-14-2012, 09:53 PM   #4
alwaysFlOoReD
I want a belly rub...
alwaysFlOoReD's Avatar
Vehicle Year: '91, '94, '77
Vehicle Make: ford
Vehicle Model: ranger, ranger, f-250
I use this vehicle for: 4x4 race, 4x4, towing
alwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud of
Default
As a temporary fix I've used airline brass barbed fittings. I've also silver soldered miscellaneous brass fittings together to make a fix.
Good luck,
Richard
__________________
My aspirations; Good thoughts, Good words, Good deeds.
alwaysFlOoReD is offline   Reply With Quote
Old 09-15-2012, 12:44 AM   #5
BRUTUS_T_HOG
BRUTUS_T_HOG's Avatar
Vehicle Year: 89
Vehicle Make: Ford
Vehicle Model: Ranger S
I use this vehicle for: everything
BRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of light
Default
Your description is a little confusing.. How about a picture?
A leaking rubber hose will just need to be entirely replaced. Easy to do
BRUTUS_T_HOG is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
