Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 04-25-2008, 01:32 AM   #1
mechjames
mechjames's Avatar
Vehicle Year: 1986
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: Daily Drivin' and Getaways
mechjames is on a distinguished road
Default misfire/backfire and loss of power
my friends 89 bronco II 2.9L has an interesting problem. at idle to about 1200 its fine, from 1200 to 3000 it'll run rough, and stutter, and sounds like its backfiring. if u pump the gas a lot and get it above 3000 it'll take off like a bat out of hell.
changed the fuel pump, pressure regulator, fuel filter, distributor cap, rotor, spark plugs, oil and air filter. pressure regulator helped a bit, but it still does it. throttle position sensor, and manifold pressure sensor has also been changed.
any ideas? fuel pressure was checked around 20 lbs before the regulator was changed, so thats what we thought the problem was.
it also seems like after we change something, it'll run perfect for a few minutes, then the symptoms return.
mechjames is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 04-25-2008, 04:29 PM   #2
IMenriched
IMenriched's Avatar
Vehicle Year: 1986 02'
Vehicle Make: ford
Vehicle Model: ranger f150 fx4
I use this vehicle for: exercise and DD & hauling college kids stuff
IMenriched is on a distinguished road
Default
Does it do this more after it is warmed up??? then check out the TFI (aka ignition module).
check to see if all the vacuum ports in the upper intake. make sure that they are not plugged with carbon & gunk. also check the back side of the throttle plate for carbon build up
__________________
IMenRiched
By the power of Lord Jesus
2 are willing to die for you.
one is a soldier, but the 1st was Jesus Christ
~few appreciate either~
IMenriched is offline   Reply With Quote
Old 05-02-2008, 11:28 PM   #3
mechjames
mechjames's Avatar
Vehicle Year: 1986
Vehicle Make: Ford
Default
it'll do it totally randomly. sometimes it'll run fine for a few minutes, then start bucking, backfiring, etc. ease off the throttle, and ease back into it, and it'll run a bit better, but not necessairly perfect.
tonight we decided to check the timing, and it was a way off. we set it to 10degrees with the spout connector disconnected, and it runs perfect til the end of the street, but really horrible on the way back. it runs its best when set 25+ on the mark without spout connector, with spout ocnnector, it jumps to 33.
i think we've decided that its a really worn timing chain. the timing light isn't all that steady either, the mark jumps around quite a bit, but then it'll be steady. sound like it?
Old 05-04-2008, 06:37 AM   #4
IMenriched
IMenriched's Avatar
Vehicle Make: ford
Default
HAve you done a thourgh check for vacuum leaks?
the distributor maybe worn and or the pick-up coil under the distributor could be and issue too.
yes the timing chain can be the problem....but before you go digging that far, check the harmonic balancer....the rubber cushion the is moulded inbetween the metal halves could have deteareated and has slipped ...then giving you a false timing setting.
Not sure...if this unit would have the 2 fuel pump system, 1 in the tank and 1 on the frame rail. you mentioned that fuel pump was replaced...if your replaced the 1 on the rail and the 1 in the tank is malfuctioning...one could get simular symtoms. was the 20psi after the new fuel pump & FPR...that seem a bit low.
__________________
IMenRiched
Old 05-04-2008, 12:10 PM   #5
mechjames
mechjames's Avatar
Vehicle Year: 1986
Vehicle Make: Ford
Default
yes done a thorough check for vaccum leaks.
i'll swap the distributor out of my working parts truck and see if it helps. it ran fine before I started parting it out.
its only got one fuel pump, and the 20psi was before the regulator was changed. it helped it a bit for power and smoothness when it runs good, but didn't help with the ignition problem. once again the fuel pump was out of my good running parts truck.
Old 05-04-2008, 04:07 PM   #6
gotmudd
gotmudd's Avatar
Vehicle Year: 1973
Vehicle Make: FORD
Vehicle Model: F250-HI-BOY
I use this vehicle for: whatever i want [ like driving over small jap cars that cut me off ]
gotmudd is on a distinguished road
Default
i'd be curious to know how many miles are on the motor and i believe you might have a timing belt and not a chain, either way it might be getting ready to puke, especially if your timing was that far off and it only seems to run half way fine at the upper end of the timing spectrum, just went through simular(SP) problem on my older full size. after changing timing set and dist. cap it runs like new
__________________
IF YOU DRIVE A JAP CAR, DON'T LET YOUR ALLIGATOR MOUTH OVERLOAD YOUR HUMMING BIRD ASS OR I WILL DRIVE MY U.S. BUILT FORD RIGHT OVER THE TOP OF IT LIKE A SPEED BUMP.
--------------------------------------------------- 1973 F250 4X4 W/390-C6AUTO W/205 DIVORCED TRANSFER.............GEARDRIVE [ my truck is my prosthetic phalus ] oh yeah, 315/75/16 big tires rock
gotmudd is offline   Reply With Quote
Old 05-04-2008, 06:06 PM   #7
mechjames
mechjames's Avatar
Vehicle Year: 1986
Vehicle Make: Ford
Default
its most definitely got a timing chain, and the miles gauge says 55,000. Now honestly its probably rolled over once, maybe even twice. we don't know. most likely got 155,000 miles on it.
Old 05-04-2008, 11:08 PM   #8
WildSide
WildSide is on a distinguished road
Default
No mention if codes are present but I would check and clean all grounds and conections andthe O2 sensor.Check the plugs for proper color too.
WildSide is offline   Reply With Quote
Old 05-04-2008, 11:40 PM   #9
mechjames
mechjames's Avatar
Vehicle Year: 1986
Vehicle Make: Ford
Default
code 14 only showed up with the off test as a memory code. PIP signal? that doesn't show up now that the computer is reset. nothing comes up with koeo test or koer.
Old 05-05-2008, 04:57 PM   #10
bradical
Vehicle Year: 1988
Vehicle Make: ford
Vehicle Model: ranger xlt short reg cab 4x4
bradical is on a distinguished road
Default
have you checked the Oxygen sensor. my 88 has had similar problems in the past. ive had to put a couple in it.
bradical is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
