| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Off-Road Rangers Under Construction Share your off-road Ranger projects here so we can follow the progress. |
Thread Tools | Display Modes |
#1 |
So I'm officially staring my build. As some of you know, I got a set of tires, and I have wheels and my lift ordered. I decided to go with 15x8 white spokes and the Skyjacker 236RHKS-A 6" lift. That has been the major expense so far but I want this truck to last me a while. Some of the trails out here are pretty rough on trucks.
My future plans are pretty much just to get the lift and tires installed and wheel it as-is until I feel I need to upgrade or break something. I'm really not expecting a whole lot from the D28 and 7.5, especially since they've got 3.45 gears. Currently I've got a decent running 2.9 and an FM145/BW13-50. The tranny is getting a little weak and hard to shift so I'll just see how that goes...planning on doing an M5OD swap someday. I would like to do onboard air with an AC compressor, too. This rig is going to be pretty much strictly a trail truck. I'd consider myself fairly good at fabricating stuff (built the flatbed in my yard with a square, angle grinder, level, and 110v wire feed) so I think I'll be alright. It's my first build though so I'm sure I will learn a ton. I'm trying to keep it on a pretty tight budget which is good for me because my mistakes will hopefully be less expensive than if I just started dumping money. So, as it sits now. I am planning on getting a new inner fender/rad support from the junkyard along with two new fenders, because as you can see these are pretty f-ed up. ![]() ![]() ![]() My interior setup is pretty much done for the moment. I stripped out all the carpet because it was rotting and used rubberized undercoating on the floor. I may try to use something else over the top of that because it rubs off. I'm also thinking about getting some bucket seats for it too. ![]() More to follow. My lift and wheels should arrive next Monday, the 7th. ![]() So I got almost all of my lift today - (7-7-08) - all but my front shocks which are backordered. I started with the rear, working in my driveway. I went from this: ![]() Got these springs put in: (old vs new) ![]() And, ended up with this. ![]() It rained for a few days so work got put on hold, but on Friday night (7-11-08) I started on the front. D28 dropped out: ![]() ![]() It seemed easier to drop the whole axle and then grind all those damn rivets out. I was right, and work progressed nicely. I took off all this, plus the front drop brackets... ![]() New drop brackets in: ![]() And new crossmember in. ![]() I then focused my attention on mounting the new radius arms. Old vs new again: ![]() The bolts on one side were easy, but the drivers side was hell. I had to use a lot of heat to get these suckers out. One on: ![]() Both on: ![]() Had to make some emergency repairs to my pants about halfway through. ![]() Axle in place, ready to be bolted up: ![]() My buddy doing something after we got the axle bolted in place, and springs and tires put on. ![]() Almost done, steering needed to be hooked up, shocks needed put in, and brakes needed bled. ![]() Got all of the above done, except shocks. This is after the suspension settled. I have a drop pitman arm but my steering is not exactly what I want. ![]() And another: ![]() Got the shocks in tonight (7-15-08) ![]() So as of right now, I'm waiting to get an alignment on Thursday and go wheel it on Sunday. We will see how everything holds up...I need to get a new bleeder for my DS rear brake and maybe iron out or ignore a transmission issue (jumps out of 1st, only in 2H though?? WTF?) I am just gonna wheel it till it breaks and swap in a M5OD I think. My plan as of right now is to stick with the V6.
__________________
1986 Ranger XL 4x4, 302, NP435/205, HP D44, RCV shafts, 8.8 Lock-rite/lsd, 4.10 gears, 35" BFG M/T --- Build Thread 1996 Ranger XLT 4x2, 2.3, M5OD 1986 F150 4x2 302/T18 1985 F250 4x4 460/T19 Last edited by Shran; 04-11-2009 at 06:21 PM. |
Tweet
#2 |
Got some new stuff put in since the last update. I picked up a nice B2 for $200 that came with good body panels, 4.10s front and rear and some nice bucket seats. Ended up with this:
__________________
1986 Ranger XL 4x4, 302, NP435/205, HP D44, RCV shafts, 8.8 Lock-rite/lsd, 4.10 gears, 35" BFG M/T --- Build Thread 1996 Ranger XLT 4x2, 2.3, M5OD 1986 F150 4x2 302/T18 1985 F250 4x4 460/T19 Last edited by Shran; 10-11-2008 at 01:20 PM. |
Tweet
#3 |
Also traded one of my junkers (89 Probe with blown tranny and other problems) for some new meat. Got a brand new set of 33x12.50x15 Wildcat EXTs to replace the junk BFG ATs that I had on it. The two ATs that I had on the back were cracked so bad that I had to tube them so that they'd hold air. The new Wildcats rub like crazy but I was planning on cutting my fenders anyway.
The original plan was to get the set of 33" swampers that I was going to have recapped but this was a damn good deal....the swampers can be spares for a while.
__________________
1986 Ranger XL 4x4, 302, NP435/205, HP D44, RCV shafts, 8.8 Lock-rite/lsd, 4.10 gears, 35" BFG M/T --- Build Thread 1996 Ranger XLT 4x2, 2.3, M5OD 1986 F150 4x2 302/T18 1985 F250 4x4 460/T19 Last edited by Shran; 10-11-2008 at 02:05 PM. |
Tweet
#4 |
So the plan now is to start building the doubler once I get ahold of a manual 1354 and grab a D35/8.8, and convert to 4 wheel disc brakes. I will be painting it too once I decide what color to go with. More pics to come.
__________________
1986 Ranger XL 4x4, 302, NP435/205, HP D44, RCV shafts, 8.8 Lock-rite/lsd, 4.10 gears, 35" BFG M/T --- Build Thread 1996 Ranger XLT 4x2, 2.3, M5OD 1986 F150 4x2 302/T18 1985 F250 4x4 460/T19 Last edited by Shran; 10-11-2008 at 07:53 PM. |
Tweet
#5 |
Year: 1988
Make: Ford
Model: Ranger
Engine: 2.3
Class: 4x4
Used For: fun
Rep Power: 12 ![]() iTrader: (0)
i like the gun rack
__________________
1988 ford ranger 2.3, 3 in lift, 31 inch tires things you need to wheel 1 duct tape fixs everything 2 bailing wire preastoric duct tape 3 zip ties modern day duct tape |
Tweet
#6 |
Hi Haters!
Year: 97
Model: Ranger
Engine: 4.0
Class: 4x4 Bolt-On eXtreme, trust me.
Used For: Parking Lot Pimping
Rep Power: 14 ![]() iTrader: (2)
haha place holder, what a good idea!
__________________
Andrew 97 Ext. Cab, front: sj brackets/8"coils/ext. rad arms, rear: 6" sj leaves + belltechs, 33's, 4.56 gears, D35/lock-right/tacked 760x's/c-clip elim, 31-spl 8.8/ptrx no-slip/discs/cowl snorkel.. |
Tweet
#7 |
Haha, yup. Got that one from you actually.
__________________
1986 Ranger XL 4x4, 302, NP435/205, HP D44, RCV shafts, 8.8 Lock-rite/lsd, 4.10 gears, 35" BFG M/T --- Build Thread 1996 Ranger XLT 4x2, 2.3, M5OD 1986 F150 4x2 302/T18 1985 F250 4x4 460/T19 |
Tweet
#8 |
Bump! For more pics!
__________________
Tweet
#9 |
Year: 1987/1990
Make: fords and only
Model: ranger
Rep Power: 16 ![]() ![]() iTrader: (0)
tell me please that you are going to swap out the 28 for a 35 one of thease days???
__________________
1987 ranger super beast__1990 ranger
duff lift_________________2.9 to 4.0 swap dana 35 and sploder 8.8___duff 3 inch lift 302 swap_______________locked front and back cab off frame ![]() 97 ranger DD ![]() 3.0 manual every thing after market headlights 4.0 S.O.H.C swap in the works |
Tweet
#10 | |
Quote:
__________________
Tweet
#11 |
See above for new pics.
__________________
Tweet
#12 | |
Resident Brewer
Year: 1999
Make: Ford
Model: Ranger
Engine: 2.5
Class: 2wd
Used For: Titties n beer
Rep Power: 48 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (6)
Sweet! Looks tons better with those new body panels..
__________________
Quote:
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
