My 87 Ranger I will be restoring soon I want to keep track of my progress and add information as I find it.
Awesom-O
206
BC Canada
I swear the fenders always seem damaged on these trucks. I have literally 6 parts trucks and my BII, and everyone of them has fenders that need repairs, either rust, major dents, or guys hacking them up for tires too big for their ride height. Not one almost perfect fender in the whole lot. 🤷🏻‍♂️
RayInStl
14
St. Louis, MO
2.3L
Well, that didn't work. Let's try something else!
I just finished reading through the whole thread. You do good work. And quick too. Seeing your pup makes me miss having a dog. These damned cats just aren't the same. I need to get a thread together for my Ranger. Guess that means I need to start working on it. Looking forward to seeing more of your work.
Ray
Terrys87
261
Anderson Mo.
Hello Awsom-O... I lucked into passenger fender but none on the drivers side. I ordered one off of ebay and was wondering where it is at. They refunded my moneu saying it is no longer available thru the company I ordered from. I have found a couple of other sites I want to order one from LMC wants twice as much with shipping so I am going to try one off another site. I hope it is not junk. I have seensome bad aftermarket but have seen some good ones too.
Hello Rayin Stl... I was just a little south of your area this past weekend. My brothers and me had a little get together as we had not seen each other in a while. Thanks for the compliments. I try to do as best work as possible. I am not as far as I would like to be on my Ranger but it is slowly getting there. I have resotred trucks in the past so have been down this road before. I will look forward to seeing your build if you start one. Let me know if you do.
Terrys87
261
Anderson Mo.
I need to replace this part. My dimmer switch likes to jam up. I’m looking for videos on how to replace it. May actually have to do it the old fashion way and look into a manual.
It looks like what I had done previously but I was getting the inner fenders and all loosened up to get the Evaporator out.
I tried just to remove the door on left side and it would not let it out. I removed inner fender and then had to remove the rest of the bolts holding the complete assembly over against the fender. It was still tight getting enough room to remove the old Evaporator and getting the new one in.
I got my new Evaporator from Orielly. Just do someone wants to know where the Orifice goes, it is into the Evaporator lower pipe.
The Orifice is below the Dryer. Dryer is clamped in between the Evaporator cover. Hope to get my Condenser and AC Compressor on later today. I still need to order a switch.
superj
2,722
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
replacing that switch is probably not terribly hard. looks like a pull the guts out of the column from behind the steering wheel type of deal
Terrys87
261
Anderson Mo.
This weeks plans are to get the rest of my AC components installed and Turn Signal switch installed and maybe AC system recharged.
I ordered a fender from Ebay, today I got a refund saying they do not have any. Tomorrow I plan on ordering another fender, just not sure which source I will order ir from. Maybe Friday I will get some more primer and at least try to get the cab ready for paint as I still need to work on the wheel arches on the bed.
Terrys87
261
Anderson Mo.
Hello suoerj.. I was watching some videos and cannot find one on thses trucks. I dont think it will be like the full size trucks. They have to cut wires or un pin the harness, I sure hope I dont have to go down that road. I can and will do it if I need to but sure hoping it is just an easy fix. Fingers crossed.
Terrys87
261
Anderson Mo.
Never had anything like this before. This is my fender order.
Awesom-O
206
BC Canada
Got your bracket in the mail today Terry. Let me know when you get it. Sent by Small packet air.
Terrys87
261
Anderson Mo.
Thanks I appreciate it. Send me your Paypal address and I will get you paid. Is there some other form of payment or even a money order I can do. I have never used Venmo or other things but am willing to learn. Thanks again!!
Terrys87
261
Anderson Mo.
To replace Signal Switch/Dimmer. Remove steering column cover and then gently remove foam dust cover and two plugs.
Then the two gold torx screws and it slides right out. Easy job except I cannot get my lever to release from old one. Otherwise a 10 minute job.
Terrys87
261
Anderson Mo.
Two issues I am having. Getting the lever out to swap to new switch. I have tried penetrating oil and I am thinking a nail or paper clip to release lever from assembly. Not happening as of now.
Other issue is my new red one has an extra electric tab on top and an extra on the bottom. I got this one from Rockauto. I will check my local Orielly tomorrow and see if they can get correct switch.
It may interchange but do want to risk it.
Terrys87
261
Anderson Mo.
If this is a release pin, I am not having any luck moving it either way. Where my thumb is.
RobbieD
2.9l Mafia
3,584
Georgia
I think that that's the pivot pin (by your thumb) for the socket that holds the lever.
Try hitting the base of the lever in the socket with Wild Dog (WD-40), and let it sit overnight. Then GENTLY tap on the lever with a plastic head hammer, on the end and inwards, a few times (to help break loose the stuck retainer). Then get a grip and pull the lever straight outwards. It may need some "tough love" but don't go overboard.
Terrys87
261
Anderson Mo.
At the tip of my screwdriver may be a release pin. It is not budging either. Could be rusted.
No members online now.
