Teal4x4
- Jun 30, 2008
- Reaction score
- 0
- Make / Model
- Ford
- Automatic
I have a '92 4L V8 auto 4x4 and the infamous dash 4x4 switch had stopped working. Instead I'd get a relay clicking sound from the 4x4 electronic module behind the driver-side jump seat, but no 4x4.
I removed the transfer motor, inspected and cleaned it as per the tech info here, but that didn't help. I went through the transfer case/module diagnostics and in doing so found that the 8-way connector to the module had turned brittle and was crumbling to pieces. I figured that was a likely reason for my woes.
Thanks to help here I got a relpacement connector. Fixed the connector issue and now back to the clicking relay symptoms. The connector I guess wasn't the issue.
I started over with the diagnostics. The continuity to the dash 4x4 switch, and voltage to the switch check out. The module blinks indicating its ok. The continuity for the connector in 2H checked out as well. So far so good.
When I did the test for 12V on the orange wire at the shift motor, the DVM went to 0V (not 12V) when the 4x4 button was pressed. Checking volatges at the module, pin 2 (blue) at the gray connector shows 5V (not 12V) when the 4x4 button is pressed. Pin 1 (white) shows 5V (not 12V) when the key is turned to run. The 5V shows at the first "relay" click noise, and dissappears at the second click. The 5V stays there if the 4x4 button is held in.
Any ideas? Am I looking at a shorted motor that is pulling down the voltages, or perhaps a bad module, even though it self-checks as ok?
Any help is very much appreciated as I'm at my wits end
Thanks in advance
Thanks in advance
