DISCLAIMER: Activities and vehicle modifications appearing or described at The Ranger Station and it’s pages may be potentially dangerous. We do not endorse any such activity for others or recommend it to any particular person – we simply describe the experiences and opinions of other Ranger/Bronco II owners. If you choose to engage in these activities, it is by your own free will and at your own risk. Any and all modifications will likely cause a vehicle to behave differently than stock. Some modifications may significantly increase your risk when driving the vehicle or be dangerous in some driving situations. Use good judgment when engaging in any activity or making any modifications. Do not take unwise risks. Consult a certified professional if you are not sure of something. The Ranger Station and the authors of these articles assume no liability for how any particular individual chooses to use the information presented here. Some of these modifications may void your vehicles warranty. Please also read our Legal notice HERE.
2019-Present Ford Ranger Tech:
If you’re looking for tech specific to the 2019-present Ford Ranger, click HERE.
Other Info:
Ford Ranger Engine Specs:
1983-1987 Ford Ranger 2.2 & 2.3 Diesels
Ford Ranger 4-Cylinder Engines (1983-2011)
Ford Ranger 2.8L V6 Engines
Ford Ranger 2.9L V-6 Engines
Ford Ranger 3.0L V-6
Ford Ranger 4.0L OHV V6
Ford Ranger 4.0L SOHC V6
Ford Ranger Engine Ratings
Ford Ranger Fluids & Capacities
Ford Ranger Fuel Mileage Ratings
Ford Ranger Engine Tips:
Kunz Korner 2.9 Performance Tips
2.3L EFI Power
4.0 OHV Modifications & Tuning Tricks
Engine Rebuild:
Basic Engine Troubleshooting
4-Cylinder Timing Belt Replacement
3.0L Rebuild
4.0L Rebuild
Rebuilding And Improving A Ford 4.0
How To Build A 4.0L OHV For Power
How To Build And Modify Ford V-6 Engines (.pdf)
Ford Ranger V6 Engine Swaps:
3.8L Swaps
4.0L Conversion FAQ’s
Ford 4.0L V-6 Conversion
4.0L Conversion On Older V-6 Fords
4.0 Conversion Wiring (From Explorer to Bronco II)
4.0L Conversion (1994 Explorer to 1989 Bronco II)
Wiring a 4.0L to a 1983-1988 Dash
4.0 OHV to 4.0 SOHC Swap
Ford Ranger V8 Swaps:
4.6L Modular Engine
Ford 302 / 5.0 History & Specifications
1996-2001 Ford Explorer 5.0L Specifications
2000 Explorer 5.0 To 2009 Ford Ranger V8 Swap
Explorer 5.0L Swap In To 1998-2011 Ford Ranger
1986 2.9L To 5.0L Engine Wiring
Install a 1996 Explorer 5.0L into a 1995-1997 Ranger
Explorer 5.0 Swap In A 2000 Ford Ranger
Install – 2000 Ford Explorer 5.0 Into 1998 Ford Ranger
V8 Swaps: 1983-1997 Ford Ranger (and all Bronco II’s)
Advance Adapters Engine Swap Information
Ford 5.0 Wiring
Turbo 4-Cylinder Swaps (Non-EcoBoost):
2.3 Turbo Swap
2.3 Turbo Install
2.3L Turbo Motor Swap Wiring Diagrams
Ecoboost Engine Swaps:
2002 EcoBoost Swap Into A Ford Ranger
Superchargers:
Eaton M62, M90 and M112 Superchargers
Vortec 4.0L Supercharger Installation Instructions
Supercharging A Ford Ranger 4.0 OHV V6
Moddbox 4.0L SOHC Supercharger Installation
Vacuum & Exhaust:
Ford Vacuum Line Abbreviations & Descriptions
Dealing With Engine Vacuum
Vacuum Hose Diagrams
Ford Ranger Exhaust Guide
Help With California Emissions
Evaporative Purge System Check Engine Code P1443
Nitrous:
Nitrous Oxide – How It Works
Nitrous On A Daily Driver
Carbs & Fuel Injection:
Ford Fuel Injection Book (.pdf)
Flow Through A Throttle Body – Coefficient Study (.pdf)
How Fuel Injection Works
Disconnecting Fuel Lines
Fuel Injection For Early Ford V-8’s
Ford 5.0 Wiring
Ford Motorsports 5.0 EFI Wiring Harness
5.0L Throttle Body to 2.9L Intake
60mm Throttle Body on 3.0L
Fuel Injection For Ford 2.8’s
2.8L Chevy TBI on Ford 2.8L
Throttle Cable Mod
Throttle Position Sensor Test
Idle Air Control – IAC – Clean / Replace
Fuel Inertia Switch
Motorcraft 2150/2100 Carb Rebuild
Throttle Body Half Shaft Mod
Cylinder Heads:
Ford 2.8L Valve Seal Replacement
Ford 2.9L Cylinder Head Replacement
Ford 3.0L Head Gasket Replacement
Cylinder Head Porting
Intakes:
2.9 MAF Conversion
Cleaning The MAF
2.3 Ram Air
2.9 K&N Filter Set-Up
3.0 Custom Intake
3.8 MAF on 4.0
4.0 Loose Intake Bolts
4.0 Ram Air
4.0 OHV Gasket (valve cover, fuel rail, intake) Replacement
ARB Snorkel (crbnunit’s Ranger)
Safari Snorkel (Mountain Mike)
Safari Snorkel (–Nathan–)
Homemade Explorer 4.0 Snorkel
Make Your Own Snorkel
Cowl Induction Snorkel
PVC Snorkel For Gen I & II
Carburetor Snorkel
Modified Air Filter Adapter
Plenum Spacers
Camshaft:
Ford Camshaft Position Sensor (CMP)
3.0L Camshaft Position Sensor – Synchronizer
4.0L Camshaft Position Sensor – Synchronizer
Miscellaneous:
Ford Ranger Emission Test Driving Cycle
Idler & Tensioner Pulley Replacement
Front Engine Accessory Drive
Ford 3.0L & 4.0L Engine Block Heater
Miles Per Gallon Calculator
Oil & Oil / Fuel Filters:
4-Cylinder Oil Filter Upgrade
Aftermarket Oil Sender & Gauge
Change Your Fuel Filter
Oil Filter Upgrade
