Ranger Tech ('19-'20)
Ranger Tech ('83-'11) Product / Build Guide Other Articles TRS Events Overlanding
Readers Rangers
  Ford Ranger Forum
TRS Store
Engine & Fuel Systems Library
Trucks Of The Month
Ranger Buyers Guide
DISCLAIMER: Activities and vehicle modifications appearing or described at The Ranger Station and it's pages may be potentially dangerous. We do not endorse any such activity for others or recommend it to any particular person - we simply describe the experiences and opinions of other Ranger/Bronco II owners. If you choose to engage in these activities it is by your own free will and at your oBwn risk. Any and all modifications will likely cause a vehicle to behave differently than stock. Some modifications may significantly increase your risk when driving the vehicle or be dangerous in some driving situations. Use good judgment when engaging in any activity or making any modifications. Do not take unwise risks. Consult a certified professional if you are not sure of something. The Ranger Station and the authors of these articles assume no liability for how any particular individual chooses to use the information presented here. Some of these modifications may void your vehicles warranty. Please also read our Legal notice HERE.
Non-Technical Articles - Make sure you check out our Resources section for Ranger history, concept vehicles, and other non-tech related articles.
New Mobile Friendly Site: Check out the new mobile friendly Tech Library HERE.
Ranger Engines
Trouble Shooting
4-Cylinders
4-Cylinder Diesel
2.3L EcoBoost Introduction
2.3L EcoBoost Specifications
2.8 V-6
2.9 V-6
- 2.9 Tips (Kunz Korner)
3.0 V-6
4.0 V-6
1999 Ford Ranger 4.0L Engine Removal Guide
Ford Ranger Firing Orders
Fluids & Capacities
Engine Ratings
Fuel Mileage
Engine Rebuilds / Swaps
4-Cylinder Timing Belt Replacement
3.0 Rebuild
3.8 Swaps
4.0 Rebuild
How To Build A 4.0 OHV For Power
4.0L Conversion FAQ's
4.0 Swap #1
4.0 Swap #2
4.0 Conversion Wiring (From Explorer to Bronco II)
4.0L Conversion (1994 Explorer to 1989 Bronco II)
Wiring a 4.0 To 1983-1988 Dash
2002 EcoBoost Swap In To A Ford Ranger
4.6L Modular Engine
1996-2001 Ford Explorer 5.0L Information
5.0L Explorer EFI Swap
5.0L EFI Swap
Explorer 5.0L Swap In To '95-'97 Ford Ranger
Explorer 5.0L Swap In 2000 Ford Ranger
Explorer 5.0L Swap In To A 1998 Ford Ranger
Ford V-8 Swaps On '83-'97 Rangers & Bronco II's
Advance Adapter Swaps
Idler & Tensioner Pulley Replacement
Misc
Front Engine Accessory Drive
Ford 3.0L & 4.0L Engine Block Heater Installation
Carbs & Fuel Injection
Ford Fuel Injection Book (.pdf)
How It Works
Disconnecting Fuel Lines With Disconnect Tool
EFI For Early Ford V-8's
5.0 EFI Wiring Harness
5.0TB to 2.9 Intake
Fuel Injection For 2.8's
2.8L Chevy TBI on Ford 2.8L
Throttle Cable Mod
Throttle Position Sensor
Fuel Inertia Switch
Motorcraft 2150 Rebuild
Turbos & Superchargers
2.3 Turbo Swap
2.3 Turbo Install
2.3L Turbo Motor Swap Wiring Diagrams
Oil & Filters
4-Cylinder Oil Filter Upgrade
Oil Sender Replacement
Fuel Filter Replacement
Oil Filter Upgrade
Vacuum & Exhaust
Ford Vacuum Line Abbreviations & Descriptions
Dealing With Engine Vacuum
Vacuum Hose Diagrams
Exhaust
Help With California Emissions
Camshaft
3.0L & 4.0L Camshaft Position Sensor (CMP)
3.0L Camshaft Position Sensor / Synchronizer
Intakes
MAF Conversion
Cleaning The MAF
2.3 Ram Air
2.9 K&N Filter Set-Up
3.0 Custom Intake
3.8 MAF on 4.0
4.0 Loose Intake Bolts
4.0 Ram Air
4.0 OHV Gasket (valve cover, fuel rail, intake) Replacement
ARB Snorkel (crbnunit's Ranger)
Safari Snorkel (Mountain Mike)
Safari Snorkel (--Nathan--)
Homemade Explorer 4.0 Snorkel
4.0 EFI Snorkel
Cowl Induction Snorkel
PVC Snorkel For Gen I & II
Carburetor Snorkel
Modified Air Filter Adapter
Plenum Spacers
Cylinder Heads
2.8 Valve Seal Replacement
2.9 Head Swap
1999 3.0L FFV Head Gasket Replacement
Head Porting
Power Enhancers
Nitrous Oxide
Nitrous Setup
Calculator
Miles Per Gallon Calculator
footer
Advertisers
The Ranger Station
   About
   Staff
   Contact Us
   Advertising
   Legal Notices
   959 Media LLC
   Copyright © 1999-2020
Submit Content
Have Info To Share?
We're always looking for good content to share with other Ford Ranger enthusiasts. Click on the 'Submit' button to find out how you can get your submission posted and acknowledged for it.
