cal74
- Nov 11, 2008
- Reaction score
- 0
- Location
- Zumbrota, Minnesota
- Make / Model
- Ford
- Manual
Just picked up a '01 4.0 SOHC that sat for a couple years. Person I got it from was told it was a fuel pump, which he replaced and that didn't resolve his issues. Not sure what else he attempted.
Will run, not sure how many cylinders it's firing on but it's tough to get it to run and it will not idle.
It's from the rust belt, but overall in pretty good shape with about 95,xxx on the clock. I did see one vacuum line off below the throttle body, but that didn't make a difference. All other lines appear to be in good shape.
Today I took the intake manifold off, gaskets didn't look terrible and the new ones were a little loose so I ordered another set.
Fuel pressure at the shroeder valve appears good. Tester I rented had a bad gasket in-between the valve and the test valve, so it leaks down from there but two turns of the ignition is showing 40 psi, three turns will hit 60.
Plugs are good, wires are good, not positive on the coil pack?
What else should I be looking at? Dread the thought of pulling the motor.
Thanks
Thanks
