Raser13
- Sep 9, 2015
- 0
- St. Louis mo
- Ford
- Engine Size
- 2.3L
- My credo
- I love it when a plan comes together
Hey guys I have a 91 ranger that has manual steering. No power. And the steering wheel is one of those rubber vulcanized over a metal pipe interior. The problem I have is that since I have to pull so hard on the wheel in tight low speed parking lot scenarios that the vulcanization has come undone on the top half of the wheel. So now when you have to pull the wheel in this type of environment it wants to slide around all Willie nillie. Not good when your trying not to hit cars. This is my third ranger wheel they've all had this problem because they are all made the same way.
I saw this steering wheel in an 02 escape.
It seems to be made a little diferntly than mine. The rubber seems to be more plastic like than rubber. So it might hold up better. I know that it is bolted on to a four pronged bracket. And that that bracket is then bolted to the shaft in the column. My question is does any one know if the escape shaft of that vintage would match that of my ranger? I really need a whee that works for this thing. Not going to change out half my truck to add power steering.
My brother has one like this in his 83 ranger that is hard plastic.
If I can find one of those I would be ecstatic as well. There's just none around me.
