justins81213
- Jan 6, 2019
- Reaction score
- 4
- Location
- Cuba,Mo
- Make / Model
- Ford
- Automatic
In process of trying to swap trans out and can't get the new used one to mesh up properly. I can get a couple bolts started to kinda hold it but I can't get the lower housing bolts to pull it on the pins. It's almost like something is stopping it from pulling in. Things we've done already are pull the trans back down, see if anything was in the way, we checked the torque converter, even went as far as trying with the old torque converter in it to still no avail. Without a torque converter in it will pull right in to the pins and sit perfectly flush! I think this should tell me that its the torque converter doing it but it won't drop in any further and what are it's it's at there's a good almost 2 inch gap between the torque converter and the bellhousing "which I'm not sure but I read that's about where it should sit" . Any ideas would be greatly appreciated as I'm way better with engines than transmissions!
