0bd1 4.0 in obd2 truck questions
pwrranger88
rhode island
4.0,2.3
ok so i just picked up a 98 ford ranger with a blown 4.0 and have a good running in my 94 with a bad frame. so im trying to figure out if i can use the 94 which is obd1 and swap all the sensors and other obd2 specific parts from the blown motor. now i've heard 2 different opinions one that the 94 motor wont work and i've also heard i can swap it with no worries. ive tried searching and didn't find much info on the swap.
3,614
IIRC the cam sensor will cause you issues. That is the biggest issue I can think of.
pwrranger88
rhode island
4.0,2.3
is it that the one from the 98 block wont fit the 94 block or is it a pain to remove/swap?
