Uncle Gump
Token Old Guy
TRS 25th Anniversary
- Sep 17, 2018
- Reaction score
- 13,493
- Location
- Ottawa IL
- Make / Model
- Ranger/BroncoII
- Engine Size
- 4.0L SOHC/2.9L
- 2WD / 4WD
- 4WD
- My credo
- Lead follow or get out of my way
Denise... It's one thing to look at that statically. It's a totally different thing dynamically. If the return spring are weak and/or damaged... they may very well have enough effort to return the shoes to the anchor pin with the drum off during a static state. When in a dynamic environment... brakes applied and self energized... generating heat. Weak and or damaged return springs might not have enough effort to pull the shoe back to the pin.Do the brake shoes return to the pin when you lightly press & release?
You also probably noted that the park brake strut was indeed removed in the pictures... so it eliminates anything park brake.
