Nailzs
- Aug 8, 2007
- 0
- Age
- 37
- Ford
- Engine Size
- 4.0l
new plugs, wires, injectors, radiator(it was leaking), rad hoses, thermostat, intake gaskets, rebuilt tranny(yeah, that was a nightmare), clutch, slave cylinder, rear main, pads, rotors, calipers, fuel filter
engine has been decarbed 3 times, blue devil coolant sealer has been ran through twice(head gaskets leak on cold starts, blows white smoke), tb is clean, maf and iat is clean, intake has been cleaned out and so have intake ports on heads(as best as i could)
the headgaskets were leaking when it was warm also, but now only when cold
some of this stuff has nothing to do with gas milage, but i wanted you all to know everything that ive done to it(that i could remember atm)
the drive train is stock, i took my 33's off and my "cold air" intake and put on a stock intake hose and breather box and put 235/75/15's on to see if that would help my mpg(thinking that the extra load of turning the bigger tires was what was killing me)
my mpg actually got worse. with my 33's i ussaully got 13.5 - 14
at this point im at my wits end. i know that my little head gasket leak would cause a loss of mpg and power, but not this much i would think
any idea's/suggestions? im at my wits end here
oh, and MAKG, i owe you an apoligy. in a previous thread of mine you told me something was wrong with my truck and i didnt believe you. then i discovered the leaking head gaskets. well, you were right, and i apoligize
