1354 fitment
spottedwolf
18
BC Canada
Ranger XLT
245
4" suspension
285/75R16
"be kind and considerate"
Hi folks,
Can you tell me if the linkage for a manual shift 1354Tcase will adapt easily........to an electric shift 1354Tcase?
If so does the electric-shift adapter have to change or does it have the manual shifter-mounting journals on it?
ericbphoto
Overlander in development
16,734
Wellford, SC
3.0L
6"
No.
The electric shift version uses a shaft from the rear that rotates and turns some magic inside to shift. The manual version uses sliding shift rails moved linearly from the front with not nearly so much magic involved.
spottedwolf
18
BC Canada
Ranger XLT
245
4" suspension
285/75R16
Thanks Eric. I figured I'd have to change the whole set-up or go with Behemoth's adapter.
spottedwolf
18
BC Canada
Ranger XLT
245
4" suspension
285/75R16
Thanks bros.
I'm looking into both methods.
00t444e
217
Southern OH
Ranger ext cab
I'ts best just to find a manual shift T case to swap in.
ericbphoto
16,734
Wellford, SC
3.0L
6"
I find it best to repair and maintain what I have.
spottedwolf
18
BC Canada
Ranger XLT
245
4" suspension
285/75R16
Thanks for all the responses. I have a 1354 with an electric shift and the coupler has the journals for the manual set-up plus the floor is built for either. That is what I'll do.
