Gui
- Nov 4, 2008
- 0
- Age
- 39
- Nanaimo B.C. Canada since 92
- ford ranger
- Engine Size
- 4.0l v6
i think ford should put a 13b turbo off a rx7 in there rangers like mazda did with there REPU trucks this thing would get better gas milage than 4.0 and give you sam or way better power went you put ur foot down and turbo spools up,or you have it run higher psi
(The Rotary Pickup (REPU) from Mazda was the world's first and only Wankel engined pickup truck. It was sold from 1974 to 1977 and appears to have been available only in the United States and Canada. Toyo Kogyo (Mazda) made trucks for Ford in the Courier as well as its own Mazda B-Series. These trucks shared many of the same parts, but the Rotary Engined Pickup (REPU) had a 4-port 13B 4-barrel carbureted engine, flared fenders, a different dash, front grille, and round taillights.)
The 13B-DEI was turbocharged in 1987. It features the newer four-injector fuel injection of the 6PI engine, but lacks that engine's eponymous variable intake system. The twin-scroll turbocharger is fed with a two-stage valve to reduce turbo lag. Output is way up at 185 hp (138 kW) at 6500 rpm and 183 ft·lbf (248 N·m) at 3500 rpm.
compared to the stock 4.0l
The 4.0 version, although produced in Cologne like the others, was only fitted to American vehicles. The pushrod OHV engine was produced until 2000 and was used in the Ford Explorer, Ford Aerostar, Mazda B4000 and Ford Ranger. Output was 160 hp (119 kW) and 225 ft·lbf (305 N·m). Though there is some variation, typically 155 hp (116 kW) is quoted as horsepower for 1990-92 applications.
the thing is that no-one know of this engine???and since turbo technology has come a long way now...
