colefouche13
- Oct 1, 2015
- Reaction score
- 0
- Make / Model
- Ford
- Automatic
hello, I have a 1984 Ranger with the 2.3 and I cannot figure out what the MCU does. so could someone help?
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
The one on the passenger side can be removed if you are using linkage controlled choke or kick down...mine was only connected for about the first six months until I burned the tip of my finger on a hot choke connection...lol...then I simply disconnected it from the carb...never actually had a functioning choke and my truck started without it just fine...most of the time.Haha yes the little box full of wires and a few vacuum lines. It has a ford sticker on it that says "MCU". well I just want to pull it out and I have a new carb coming with none of the electronic stuff on it. I'll check the wiring diagrams and vacuum diagrams to see if anything important goes through that, if not it's coming out.
Pretty much that's all there is...and after driving a carbed truck for 14 years I thought I knew all I needed to know about them...I was wrong, of course...I'm no expert on carbs, but I thought the coil, alternator, and starter were the only important things that had wires.
Well the distributor advance is defiantly temperature activated. There are three vacuum switches on the intake manifold that are part of the cooling lines. The switches are temperature activated and once the engine coolant reaches a certain temperature they open up. The vacuum advance on the distributor connects to one of these switches so that won't be a problem with the new carb, or even with pulling the whole MCU out.The contents of the box look like 1)vacuum canister, 2)EGR solenoids that control vacuum apply and hold to the EGR diaphragm, and 3)ignition module. In this case, ignition module also handles diddling with the carburetor mixture based on speed, temp and load.{as a guess}
If you replace the carburetor with aftermarket, the only thing I would be concerned with is vacuum to the distributor advance, other than carburetor stuff such as power valve, jets, mixture adjustment, and fitting an air cleaner that would keep out the abrasives that want to destroy the rings. Oh, and have hot air if needed for cold weather operation. Nothing like trying to drive with ice forming in the carburetor. You go slow, and eat a LOT of gas, until you pull over and let things melt.
tom
Please take a picture so I can see that's exactly what I want to do to my carburetori have a 2.0 with a one barrel so take this for what its worth. i cut and removed everything from that box. i had to get power to the choke and the coil after i did this. i then remove every vacuum line on the truck. i ran one vacuum line from from a ported vacuum port on the carb to one of the temp switches on the intake then to the dist. the truck runs 300 times better than it did before. i can take pic tomorrow when there is light if you want.
i, actually getting ready to rip all of the carb stuff out and put gm tbi on it( don't beat me. i work with this system a lot so i know it and it works well)
let me know if i can help in any way. i cant say i will be of any help but ill try
