1985 Bronco 2 starter bolts
ikesdad
Grand Junction, CO
What are the starter bolt dimensions on an 85 2.8 ? One fell out on the road and got lost and the other got misplaced. Local Napa has no idea.
franklin2
1,776
Virginia
I am assuming the manual transmission starter is the same as the automatic? I have a TKO 5 speed laying here, the starter bolts thread into the transmission. The threads on this transmission are 10mm diameter X 1.5mm thread pitch. I estimated the bolt length is going to be 40mm long. You can get some a little longer and a little shorter depending on if you are going to use a lockwasher.
