jbldsdad
- Dec 19, 2020
- Reaction score
- 3
- Location
- 83634
- Make / Model
- Ford Bronco 2
- Manual
[1986 Bronco II, 2.9 v6]
Great help from this forum over the past few years helping me resurrect this gem from the dead.
Detailed her last week to a beautiful shine.
With the summer still on, I figured I'd take on the (stock) A/C. Replacing hoses, I figured I'd check the compressor before closing the checkbook.
With a direct jump from the batter, car running, the clutch engages and runs!
Otherwise...no A/C from inside the cabin, so I started troubleshooting. (Clearly I'm stuck, or I wouldn't be posting...)Found the 30A fuse blown, so replaced that.
I add a jumper between pressure switch blades (Just to eliminiate a possible failure there) and the fuse blows.
I removed all tape and plastic casing around the B/lg wiring headed to the compressor for a visual inspection, and I see no visible shorts. I confirmed the ground wire is clean/secure on the passenger wheel well. Just for kicks, I test for voltage on the A/C clutch connector (red lead to the battery "+"), and both blades read 12.38v.
Here's where I'm raising my hand for what to check next.
Other than the fusible link, I wouldn't think there'd be a closed circuit between those two blades, so maybe a short in that connector?
I'm also curious about the BK/Y wire coming off the A/C compressor (one leg goes to the pressure switch, the other seems to head to the EEC), as that white connector looks confusing. (4 red wires, B/Y and a ground wire all meet)
Any recommendations on where the short might be?
- A/C button pressed (defrost mode), the light illuminates...
- WOT relay (picture attached) seems to fit the "2.3L EFI" diagram from this post. With the WOT relay removed (KOER) I read:
- 13.63v from the far left red wire (See picture below)
- .43v from the center red wire
- 13.73v from the Lg/P wire
- -.04v from the B/lg wire
- WOT relay installed (KOER) I read:
- 13.60v from the far left red wire
- 13.6v from the center red wire
- 13.65v from the Lg/P wire
- 13.65v from the B/Lg wire
- 13.6v on the near-side of the pressure switch connector.
