1986 Ford Ranger AC compressor model
wildbill23c
Ham Radio Operator
578
Southwestern Idaho
215/70-R14
Looks factory controls I believe, the components look like a dealer/aftermarket install for the previous owner of the car, I appreciate all the input from people seems like I have a little work ahead of me to get the ac blowing cold again
That is the factory equipped HVAC panel...I'll run out and get the dealer installed AC photos on my 87 Ranger.
wildbill23c
Ham Radio Operator
578
Southwestern Idaho
215/70-R14
Even the installation bracketry in the OP is incorrect for anything...that whole system was cobbled together by somebody probably as a way to sell it for more money because it had working AC for a while, probably long enough to get it sold LOL. Being that old it definitely would have had R12 in it. R134A was around in the early to mid 90's but mostly started being used in the late 90's by all automakers.
I'd go grab the proper AC components and put it together properly. Most likely with all those hose clamps on there it had several leaks, and eventually it quit working and...well now you are left with cleaning up someone's half ass attempt at having AC. Most of the junk yard trucks I've ran across either have factory AC or no AC at all in my area. The trouble is that system will need to be disassembled completely and the condenser and evaporator flushed out if not replaced completely...who knows what kind of contaminants went through that system and if the AC Compressor did in fact fail, it usually will release metal pieces into the system...the AC compressor could in fact work, but without a charge of refrigerant in the system you can't find out as there has to be enough refrigerant in the system to allow the low pressure and high pressure switches to function thus turning the compressor on and off.
On the back of the compressor it looks like service ports and those ports do look like the newer R134a connections, so its possible someone did install it and did have R134a in the system....course like I mentioned it has probably all leaked out by now so the system won't work. Check all your electrical connections and make sure the compressor is getting power to the clutch. Someone had cut some wires under the hood of my Ranger and they were to my AC compressor clutch, so the AC wasn't working...easy fix for me, but with the cobbled together mess on the OP's truck, its most likely something far more difficult and expensive to repair.
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
@Chazg DM or call me I have entire system off an 88 you are more than welcome to was not working but was intact. 8042393214
wildbill23c
Ham Radio Operator
578
Southwestern Idaho
215/70-R14
^^That would be the way to go OP....get the whole proper system it would also make getting parts much easier in the future.
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
Free just pick up or pay shipping
Danec71
Washington
I have this very same system. Compressor and controls. My compressor works fine but I did google the tag on it and did find them for sale. My system uses the same clamps and everything. Maybe if not factory certainly some kind of aftermarket kit that may be common to find parts for.
Danec71
Washington
This is what you have. They used these along w
Thanks for the info that looks just like the system on my truck
Could you post a pic of the tag or a link for the google search of the company you found
[/Q
This is what you have. They used them but not as much as the one you always see. Not sure why some trucks got this. Some people think there systems patched together but look like the were factory or after market factory parts
Danec71
Washington
It’s a Ford hr980 ac pump if it doesn’t show well in the picture.
