1986 Ford Ranger Manuel Transmission Swap
TSS246
Barstow CA
I have a 1986 Ranger 2.9l V6 4x4 with the Mitsubishi FM145, I need a new trans and instead of rebuilding the FM145 I was thinking of upgrading to the Mazda M5OD trans since it should be a straight forward process. My questions are, will the transfer case bolt up to the M5OD, is the length of the trans the same or will I need new driveshafts, and is there any other problems I should expect. Thanks in advance to anyone that can help!
TSS246
Barstow CA
Also I should mention I have the BW1350 Transfercase with the electronic shifting.
gaz
680
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
@TSS246 ,
As long as both transmissions are set up for 4 wheel drive (same output shaft) the drive shafts lengths are the same. The same is no true of the flanges; you will need to swap your driveshaft flange on the transfer case side.
TSS246
Barstow CA
@gaz
@TSS246 ,
Sorry im a little confused, I was planning on reusing my BW1354 transfer case on the new transmission. Why would I need to change the flange?
gaz
680
Wa, Bremerton 98310
@TSS246 ,
My mistake, I failed to digest your statement.
As long as both transmissions are/were from a 4 wheel, the transmissions are the same length.
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
The M50D is longer than your FM145. Your transfer case will bolt on. Driveshafts from a truck with a FM146 or A4LD will be the correct length for the M50D
