1987 Ford ranger Dana 44 solid axle swap
Stowelltravis
83301
I removed all of the old front and and put James Duff coil towers on. Now the coil have a curve to the and was wondering if I need to fix it or if I should just drive it. Any help would be awesome.
Bird76Mojo
1,265
IL
I assume you used an axle with the cast wedges. In that case, the only option I know of would be to narrow the axle until the springs line up, or space out your coil buckets.
If the wedges are welded on, then you could grind until they're loose, move them inward, and weld them in place.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I wouldn't drive it 10 feet like that... like the bird said, gotta move the lower spring mounts in or make custom upper towers.
Junk Collector
Truck of Month
4,800
Rapid City SD
Hey that's how mine looks... and I have a narrowed front axle too... It's been like that for 7 or 8 years now.
Lots of suggestions out there. You can try to redo your lower coil cups so that they are angled inwards - allegedly that has helped some. Marginal improvement on mine. I just gave up and have been living with it looking weird.
What coils are you running? I'd be talking to Duff for suggestions and will be curious what you end up with.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Is that a redneck limiting strap or a bad job hooking it to a trailer? :icon_rofl:
Junk Collector
Truck of Month
4,800
Rapid City SD
Ignore the strap, I was just using it to pull the body sideways so that the track bar could be hooked up (it's not in the pic.) I had ripped the track bar bracket off the frame prior to that picture being taken.
Stowelltravis
83301
Also the coils a from a 1977 Ford F-150 stock coil and the axle is full length.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
It is a lineage issue. Canting the seats will help....or solve it. I do that with angled pipe seats using low ppi with ttb. I had 140 ppi springs at one point with air bags which allowed for Max articulation but would flip the spring without canting the seats.
With the straight axle it is simpler.... Move the bucket out or move the lower seat over. Simple as drilling two holes with an angle iron stand off.
70s 2wd buckets work perfect.
