matt12305
- Nov 8, 2021
- 1
- Washington
- Ranger 2WD 2.9l
I have a 1988 ranger, it's got the 2.9l engine.
It has been sitting for probably 8-12 years. After replacing pretty much all of the fuel system parts (both fuel pumps, file filter, fuel tank, professional injector cleaning) I was able to get it to start. It does start up pretty quick, and it runs okay until it wakes up.
After it's warmed up, it doesn't idle right, the rpms fluctuate up and down. I replaced spark plugs, didn't help. Last time I worked on it, I replaced the map sensor..that seems to have made it worse. After replacing the map sensor, it ran better at first. But once it warmed up, it was so bad it couldn't even stay running, it would die unless I gave it gas. I suppose it could be a bad map sensor, I still have the old one but I haven't put it on to check.
Aside from it running poorly, it smokes like crazy. Its a thick white smoke coming from the exhaust. I'm not sure if this could be from cracked heads or maybe work out rings burning oil.
This car is not my main focus right now, I have two other cars to get on the road first. But I wanted to start doing some research so I can have ideas of what I need to look at. I hope for this to be my daily driver one day as it only has 77k miles.
Any ideas of what the problem(s) could be? Thanks
