1988 Ford Bronco 2, A4LD Safety Switch Location
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
215/70-R14
Seems the switch that tells the truck its in park is going bad, where is the switch located?
8,372
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
215/70-R14
Thanks, I was hoping it was just a safety switch so I could bypass it, seems its failing have to move the shift lever around a bit for it to finally realize its in park LOL.
8,372
You can just connect the START wires together
2 wires will be for the reverse lights, one of these will have 12volts with key on, usually a purple wire
Then an OUT to reverse bulbs, often the black/pink wire
Once you ID those 2 leave them connected to the switch, assuming they work now, lol
Cut the other 2 or 3 wires and twist ends together, its now by passed, leave enough wire to re-splice down the road
1 wire comes from the ignition switch, has 12v with key in START position
the other 1 or 2 go to starter relay(solenoid) "S" post and to TFI module START pin
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
215/70-R14
Once you ID those 2 leave then connected to the switch, assuming they work now, lol
Thanks RonD, I'll look at it this weekend and get it temporarily bypassed till I can replace the switch. Just started having trouble with it last week first time it happened I thought the dang ignition switch died, then thought well I'd move the shift lever and then it started so at least I know what it is, and I assume it would start in neutral too or does that same switch have anything to do with being able to start in neutral?
8,372
Yes, it should also start in neutral
If you have a column shifter then could just be getting loose, a common issue on Ford Trucks
Google: Ranger loose column shifter
Loads if videos and fixes for this issue
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
215/70-R14
Nope its a floor shift, don't think the Bronco 2 had a column shift till the 89 model year LOL. Wish it had a column shift though...I'm sure I could install one but way too much work for my lack of mechanical brain and lack of patience LOL.
Thanks for your help RonD. I'll look at it this weekend and see what's going on...maybe the shifter itself is just out of adjustment....wouldn't surprise me at all LOL.
