Munchie1615
- Apr 17, 2021
- 4
- Gainesville, FL
- Ford Ranger
I forgot to put that in the first post, the first thing I checked was the inertia switch, as I had a 2004 Ranger Edge that always tripped and thought that has to be it! The inertia switch was good, and I definitely have fuel at the rail, when I depress the schrader valve it squirts out and also I did the fuel pressure test and was within a good range. Often times if I continue to try to crank after doing different things I'll get a fuel smell - that's why I thought "Man! Maybe it IS that ECT sensor!" but so far those ohm readings seem to be in range for the temp it was outside when checking. Now I'm scared to try the voltage test again since that's when my ECM went belly up! haha
I'm going to compile some more pictures from what I've taken out and I'll try the spark plug to ground.
I've been scratching my head for about 5months giving my brain a rest in between troubleshooting attempts, that's why I figured it was time to try and get some more opinions, suggestions, maybe find that one anomaly I haven't found or tried... I almost feel like it's an electrical gremlin somewhere but I swear I've checked everything that would STOP the engine from at least turning over.
More to come later today.
Mary
Mary
