1990 5.0 swap thread (project Jenner)
Maui-sprint
65
Oahu, Hawaii
So I am starting the swap process this week now that the engine and trans is ready to go in, Im going to name it Project Jenner (old busted pickup that thinks its a hot young mustang)
I can now pull the old engine and trans out.
Im using an 98 Exploder 5.0
B303 Cam
Trickflow valve springs
Trickflow lifters
Trickflow pushrods
Proform roller rockers 1.7
Sn95 fuel rail
Explorer injectors 19lb
Ricks rangers engine plates
4.0 rubber mounts
A9L computer
M5OD-R2 trans
Luk 11" clutch
More parts to come my focus is engine and trans out and in this week and mostly wiring. Other stuff that inst as time consuming will follow.
Per your description the M5R2 trans you initially used was from a 1990 F50. However, it appears you have a 97-03 top cover on it. Did you have to modify the cover or trans to get this to work?
Ramcharger90
1,708
N/A na
306, Bcam,
I didn't modify the transmission. The junk yard must have misidentified the one they sold me.
2drxploder
436
usa
ranger
347
lower
235 on 15s
no converters in exhaust? just weld bungs in downpipes?
Ramcharger90
1,708
N/A na
306, Bcam,
51197
With bungs in the down pipes
