1990 Ranger 2.3, hard to start, runs bad
buell-eyed-devil
21
Wesley Chapel,Florida
FORD
5.0-ZF in process
3"body on new poly body mounts
Hey ya'll, watch this
My son has a 90 Ranger with the 2.3 engine. Fuel pump went out so he replaced it and filter. Good for a while then started missing and hard to start. Had low compression in 1 cylinder so we replaced head gasket, spark plugs and wires and battery. Still no luck. Does it have a MAF sensor and could this be the problem?
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
I'm guessing it still has low compression and/or the timing marks were not lined up correctly on all 3 sprockets
buell-eyed-devil
21
FORD
5.0-ZF in process
what is 3rd sprocket?
buell-eyed-devil
21
FORD
5.0-ZF in process
should be for oil pump...cant see what difference that would make
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
Unless it has a cam sensor.... a 1990 likely does not. You still need to verify compression and cam timing
buell-eyed-devil
21
FORD
5.0-ZF in process
turned out to be bad coil pack
Andy D
10
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
Thank you for the follow up. :D
FritzTKatt
4
Ohio
Oil pump sprocket doesn't have a timing requirement. It doesn't even have a mark.
Was it the primary or aux coil? If the aux went bad, swap the primary for new aux. When the old one fails it'll still run. Or just keep that in mind for later emergency use.
