1990 xlt tune up question
Duane Becker
Elk, Washington
Ford Ranger xlt
Hello, I just acquired at 1990 Ranger 4x4. I want to give it a tune up. Runs ok, but seems to have a minor miss. I'm replacing the spark plugs and wires. What do you all suggest for a brand of plugs and wires. Any other suggestions for tune up as well. Its a 2.9 engine.
8,370
Welcome to TRS :)
2.9l has a distributor with TFI module
These need to be timed
Google: ford ranger 2.9l spark timing
You need a timing light of course
Engine needs to be warmed up
You disconnect SPOUT wire, and loosen distributor
then re-start engine
Ford specs 10deg BTDC but most prefer 12deg BTDC
Any good brand of wires are OK
For spark plugs Motorcraft or Autolite are preferred but NGK are also OK
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Don't forget to put your tools away!
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Welcome to the site.
apcblue
Nevada
My truck failed smog due to high fuel mixture while idling
8,370
You should probably start your own thread
Go here: https://www.therangerstation.com/forums/index.php?forums/general-discussions.2/
General discussion forum
Above the 1st post you see "thread title" click there and put in a title
Then ask your question in the "message" area
Include year of the Ranger and engine size, also manual or automatic transmission can matter and 2WD or 4x4
There are several things that can cause higher emissions at idle, depends on the engine in some cases, 1990 Ranger had 3 models, 2.3l, 2.9l and 4.0l
