- Mar 4, 2020
- Reaction score
- 7
- Location
- Indy
- Make / Model
- Ford Ranger
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- '88 Turbo Coupe swap
- Manual
- 2WD / 4WD
- Solid Axle Swap 4x4
- Tire Size
- 33"
I am not trying to re-invent the wheel here and haven't found any solid answers through the web. What FMIC do people run in their first gen? Sure the '88 TC IC works, but I would like to go with a front mount and utilize the blow off valve I have on the shelf. While we are at it, I could use a rebuild kit for the IHI unless someone has a solid unit they would like to move on from. Lastly, for now, I am running a stock fuel pump from the Ranger. I won't need a 255 lph pump, but would like to wire in a 190 lph. Anyone have a part number? Is there a solution for a float that doesn't break when offroading? Replaced the whole unit and the float broke second day on the trails.
Excuse my ignorance as I am still fairly fresh to the offroad world as well as the 2.3 lima. Thanks!
