1992 ranger 4wd needing interior part
T.r.88
Tony$hollie21
Was wondering if anyone knew where to get the interior box for the 4wd module for a regular cab, mine is just laying in the floor behind the seat and I would like to put it back where it’s supposed to be so it don’t get messed up but I cannot find that interior pieces, thanks guys for any help
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
T.r.88
Tony$hollie21
8,372
Welcome to TRS :)
Try here: https://www.car-part.com/
1992
Computer box Not Engine<<<part
USA?
Sort by Distance
Your Zipcode
Search
New window
Select transfer case
Search
Should show you local places that have the controller and you may be able to get just the bracket if yours works
Josh B
1,987
Oklahoma
Is it only found in Rangers, or is it also in Explorers and Broncos?
My driver side seat release broke off at the screws not long after I got it and I have not found a replacement anywhere, so it has been a LONG time since I've seen the back underside of that seat, I never knew these things even existed
8,372
1988-1994 Rangers had the 4x4 controller behind driver's seat, mounted behind the plastic trim cover, on a bracket
BII were also behind driver's seat but behind the side panel
Explorers usually had these behind Passenger kick panel
Josh B
1,987
Oklahoma
Would one from an Explorer replace one on a Ranger?
I meant if duck tape wasn't a problem :D
8,372
You could always use self-taping screws if you don't mind a couple of holes in the back of the cab :)
00t444e
217
Southern OH
Ranger ext cab
That whole system is garbage, swap to a manual shift transfer case and do away with it.
